Do you have a suggested backup for a Raspberry Pi?
Problems or questions about Lights-Out on all Windows platforms are answered here
BSmith7760
Beitrag von BSmith7760 »
Hi, Martin
Thanks,
Bob
Rsapberry Zero W.PNG (58.07 KiB) 6870 mal betrachtet
JoachimL
Re: Do you have a suggested backup for a Raspberry Pi?
Beitrag von JoachimL »
I was considering to offer a backup client for my own software, but frankely, backup on *x is a nightmare compared to Windows. Unlike Windows volume shadow services, snapshots (e.g. LVM, btrfs) are not configured out of the box with any distro I am aware of. The consequence is that consistent, online, application-agnostic backups are impossible.
You can
  • search for a backup solution specific to the applications you run
  • shutdown the system and copy the SD card offline
  • do away with the Raspy and run *x virtualized on Hyper-V - then Windows backups (including mine) work great.
Regards, Joachim
I'm afraid not. A good backup solution for Linux is "Veeam Agent for Linux free", but this requires an x86 CPU.
Most simple file-based solutions run in the user context and this makes it hard or impossible to use with lights-out.
Regards
BSmith7760
Ok..Thanks to both of you...;-)
