Unable to access WHS 2011 server from Windows 10 client
Problems or questions about Lights-Out on all Windows platforms are answered here
escrime
Beitrag von escrime »
I have Windows Home Server 2011 running on a HP Microserver but have recently been unable to access it from a Windows 10 or 11 clients. I keep getting "\\[My_Server] is not accessible. You might not have permission to use this network resource...This user can't sign in because the account is currently disabled".
The user credentials (account name and password) are the same on both client and server and the account is enabled on the server. I am not sure if this is related to a recent Windows update. It was working so I am not sure what is the fix. Hopefully someone can point me in the right direction.
Re: Unable to access WHS 2011 server from Windows 10 client
You're talking about file access? Not related to Lights-Out?
Is that the only client with this issue?
escrime
Hi Martin,
Yes, file access. Light-Out is fine. It stopped working on October and I posted a request on a Microsoft forum wondering if this was related to a Windows Update.
The advice was:
Check the user credentials
Check Local Policies > Security Options then ensure "Accounts: Administrator account status" is enabled and check "Network access: Sharing and security model for local accounts" is set to Classic.
Verify Time Sync, make sure both machines have synced system clocks mismatched time can block auth.
Check Windows 10 Update History for a recent update may have changed NTLM or SMB behaviour. Try uninstalling the latest update temporarily to test.
I did all this and it still doesn't work. I received no further response so I thought I might ask here.
I can access the WHS server via Remote Access using the admin credentials, but I cannot access the server from either my Win 10 Pro or Win 11 Pro clients using my regular account credentials. These are the same on both clients and WHS 2011 server. It rather limits the usefulness of the server!
Have you checked the event logs on the server (especally security)? Any hints?
escrime
Yes; nothing in the event logs including security.
In the WHS 2011 dashboard I see the user is active, which is why I do not understand the error saying the account is disabled. The username is the same on both WHS 2011 server and the client (on an SBS 2011 Essentials domain). The passwords are the same.
However, when I go to User Accounts>Manage accounts on the server, only the Administrator and Guest accounts are shown. I would have thought all the accounts shown in the WHS 2011 dashboard should be there too.
I no longer have WHS 2011 running, so I can't check. Can you please open Computer Management and look there for users and groups. Maybe you can enable the users there.
escrime
Thanks Martin.
I don't understand this at all. The user is enabled. I can log in via Remote Access using the admin account, but when I try the user account it says remote access is not enabled for the user. It is.
The error messages are wrong. Something is very wrong. I will try Microsoft directly. Maybe it is time to retire WHS 2011, though handy as a local backup for photos.
