Hi. You have a picture of a Microserver on the front-page of your site. I have a Microserver and my thoughts that your, probably fantastic, software could help me save some money on my electricity turned out wrong. HP Microservers, certainly mine, does not support any kind of sleep or hibernation. It only supports shutdown, which is not helpful, as WoL doesn't appear to work from a full shutdown. If you have a way to make your Lights-Out software work on my server I would really like to hear about it please.
Thanks
Regards
Peter
HP ProLiant Microserver Gen10
plsm5882
Re: HP ProLiant Microserver Gen10
You can use hibernation. That works with WOL.
Please enable hibernation in your powerplan or execute
powercfg -h on
Regards
powercfg -h on
Regards
