Can't login "An error occurred while sending the request."
Problems or questions about Lights-Out on all Windows platforms are answered here
Gait
Beitrag von Gait »
How can I fix it?
Schermafbeelding 2024-01-24 174830.png (8.94 KiB) 10952 mal betrachtet
Re: Can't login "An error occurred while sending the request."
Please recreate the SSL certificates on the server. Run Lights-Out SSL configuration.
Regards
jenius99
Beitrag von jenius99 »
Hello Martin.
I have the same issue when I tried to upgrade to latest version. So I tried a fresh install but I get the same error. I did delete my old SSL certificate on the server and created a new one for 1 year. I did notice server by lights-out had an expiration date of 26-01-2024 after a fresh install?
This seems to be the expiry date of the old certificates. They are stored in the certificate store and are not removed when uninstalling.
jenius99
Thank you, Martin. I removed them manually and it worked. Didn't realise they weren't uninstalled automatically.
