how to delete computer from LO server
Problems or questions about Lights-Out on all Windows platforms are answered here
zva
Beitrag von zva »
Hi all
Would anyone know how to remove computer from LO3 server ?
I have a LO3 server and one of client computer has reinstalled system with new computer name - IP an MAC is still the same.
When I try to connect to the server -> the line with old "name" is vissible on the console, the new line with new "name-1" is added, but only for a few second (10-20) - then it is dissapear...
In client side currently joined server is filled but the LO icon is with question mark.
It looks like collision between two records with the same IP and MAC.
I need to delete the line with old "name" or rename it - how??
My support has expired, hence I'm asking the community on here.
Thank you
Re: how to delete computer from LO server
Is that an Essentials/WHS? In that case you can only delete the client from the Dashboard under Computers & Backup.
If that is a standard Windows server, then you can delete the client in the Lights-Out Console. Simply right click...
zva
Beitrag von zva »
Hi Martin
thank you so much for the right solution. We have an Essentials - delete from dashboard has helped...
Than you
