404: Server not found.
Problems or questions about Lights-Out on all Windows platforms are answered here
Radicofani
Beitrag von Radicofani »
I got me a license for LO and LO Mobile. I can not connect externaly to my server with the LO Mobile version on iPhone 11.
System: EX490 E8500 4Gb RAM
OS: WIndows Server standard 2019 with Essentials 2016.
I think I did it all by the book:
- Portforwarding 7784 in the router.
- WOL checked. (Frtitz! box)
- Checked portforwarding 7784 in the windows filrewall.
- SSL binding are okay.
- I can ping the server at the desired IP adress.
- Remote Desktop is working.
- http://(servername).remotewebacces.com is working.
- I can connect the app on the internal network. (port 7782)
Externaly (port 7784) I can not connect........
I am out of options / ideas.......
Does anyone has a clue or idea?
Kind regards,
Radicofani.
Radicofani
Re: 404: Server not found.
Addition:
If I try to connect in a webbrowser with:
https://(servername).remotewebacces.com:8874
I will get a security warning and after continue it goes directly to the page
http://(servername)
Where is can download the client installation software.
If you get a security warning in your browser with https://(servername).remotewebacces.com:7784, you have not assigned the correct Essentials certificate to port 7784.
Please fix that first.
Then open Lights-Out Mobile and enter (servername).remotewebacces.com:7784. That should now find the server.
Regards
Radicofani
Thanks for your answer.
I checked the bindings again and they look fine.
How do I assigne the correct Essentials certificate to port 7784?
Radicofani
Even with the Go-Daddy cetificate is will not work........
I am out of options, ideas, thoughts........
Yes, you assign the GoDaddy certificate to port 7784.
Please contact support at green-it-software dot com so we can exchange additional private information.
Regards
