Client Computer says "Beta test version is expired!"
Problems or questions about Lights-Out on all Windows platforms are answered here
jmone
Beitrag von jmone »
My server is Version 3.7.2.4869 and has supported and maintenance until 4/02/2023. A client PC (also on the same version) has started to complain that "Beta test version is expired!" for the Lights-Out 3 Console. How do I update the client computer?
Thanks
Nathan
Re: Client Computer says "Beta test version is expired!"
Download the latest console from your server.
Go to https://servername:7782
jmone
Beitrag von jmone »
Thanks - did both the console and the client. The client is saying the server is off-line, and that the client is not licenced (but the server is up and running... and doing backups). It seems the Lights Out client is not connected to the Lights Out server (but the console works fine).
jmone
Beitrag von jmone »
OK - I detached the client and reattached and that seemed to work.
jmone
Beitrag von jmone »
FWIW, There is a bit of a typo in LO. This client PC is has the following information from Windows "About PC"
Edition Windows 11 Pro for Workstations
Version 22H2
Installed on ‎13/‎05/‎2022
OS build 22622.290
Experience Windows Feature Experience Pack 1000.22632.1000.0
LO, reports it as: "Windows 11 (Windows 10 Pro for Workstations), 22H2"
Thanks, will fix it.
