I am currently using Lights-out v1.6 on my WHS2011. I tried upgrading to v3 but had issues with my server constantly rebooting and then not booting up at all. I restored the server from a backup and all was well again. I am still thinking of upgrading but thinking it would be better to go to v2 first, what is the recommendation on this, is upgrading to v2 and then to v3 a better idea? Are there any considerations to doing the upgrade so that I can avoid experiencing issues again? I am also wondering if upgrading from v1.6 on a WHS2011 is worth doing.
Thanks.
Upgrading from v1.6 to v2.02
davidt99
Re: Upgrading from v1.6 to v2.02
Hi David,
you can upgrade from v1 to v3 directly and Whs 2011 is still supported in the v3 line.
Have you followed the procedure here: https://help.green-it-software.com/help ... tials.html
Regards
Regards
davidt99
Thanks Martin, I will have another go.
