Connection Lost when installing Lights-Out3
Problems or questions about Lights-Out on all Windows platforms are answered here
Slingers
Beitrag von Slingers »
Hi, I'm trying to install Lights Out version 3.5.1.4642 onto my backup server (WHS2011) but in the dashboard there is a message in red stating "Connection Lost, trying to reconnect..." and the install doesn't seem to work. I've uninstalled and reinstalled the software and this hasn't solved the problem. Any ideas welcome?
Re: Connection Lost when installing Lights-Out3
Please run the Lights-Out SSL Wizzard and assign/create valid certificates. Click on Start->Lights-Out->SSL Wizzard
tpham
Beitrag von tpham »
I have the same issue and dont know how to fix it. Attached are a few screenshot. It seems like some sort of SSL No Binding issue.
Screenshot 2020-10-07 121709.png (20.82 KiB) 8834 mal betrachtet
Screenshot 2020-10-07 121825.png (13.88 KiB) 8834 mal betrachtet
Screenshot 2020-10-07 121854.png (14.4 KiB) 8834 mal betrachtet
What version are you running (Lights-Out and OS)?
What certs are offered in the second screen shot?
Regards
Mandraquinet
Beitrag von Mandraquinet »
First, sorry for my bad english, I'm french !
Same for me for a week and suddenly.
It must be an SSL certificate problem but I did not touch anything on the Windows 2012 R2 Essential server. I tried SSL-wizzard but it prevents me from accessing the remote connection. So I deleted the 2 new SSL certificates then I regenerated the initial ones. Now, Web access works but no connection to Lights-out.
This comes from new conditions from Apple ?
What should I do please ?
Click Next, select "use existing certificates", Next, Next...
