Device Properties for Server Missing
Problems or questions about Lights-Out on QNAP QTS are answered here
Jennings
Beitrag von Jennings »
In the Lights Out 3 Console, the server run time bar is missing. It shows on my WHS2011 Essentials dashboard.
Do I need to enable it somewhere?
Thanks
Ken
Re: Device Properties for Server Missing
Hi Ken,
Have a look at your action settings. If you have "Do Nothing", then the server/NAS is suppressed by default (because it's running 24/7). To make it visible, go to Settings->Console. There's a check box to enable the server.
Regards
Jennings
That did it. Forgot that I had to do that to WHS about 8 years ago to make it work. Time for new hard drive for the old brain! Thanks.
