My PC is hibernating at odd times
Problems or questions about Lights-Out on Synology DSM are answered here
BeverlyB
Beitrag von BeverlyB »
I updated lightsout to 3.5.0.4597 and my system is hibernating at unexpected times. I have it set to hibernate after a backup but a backup didn't happen (wasn't scheduled) at the time this occurred. I also have a calendar item set to wake my system 5 minutes before a scheduled backup (using active backup for business) and to do the default action at the end time after 20 minutes of inactivity because I still can't tell it to stay on with backup activity (ABfB is in the list but is unchecked and greyed out).
When I log into my PC after turning it on, it hibernates soon after. Sometimes I see a screen from lightsout counting down and can cancel it sometimes I don't.
I checked my PC power settings and it is set to never go to sleep when plugged in (which is most of the time).
My PC is running Windows 10.
Re: My PC is hibernating at odd times
Please send me your client logs via email. That me be an issue with the beta version.
Simply zip the whole folder c:\programdata\LightsOut3Client\Logs (via right click, send to compressed folder). If you do not see a folder c:\programdata, then open explorer options and enable "show hidden files and folders".
Regards
BeverlyB
I sent a PM with the compressed logs folder attached
EDIT: IS it normal for a PM to sit in my outbox rather than "Sent messages"?
That's normal until I read the PM. Then it's moved to sent items.
I'm looking at your logs right now and will come back.
Found the issue. Thanks for reporting!
Will be fixed in either the next beta or the final release.
Thanks
BeverlyB
That's good news! While I'm waiting for the update, I uninstalled the Lights Out client.
