Server behavior changed after hardware upgrade
Problems or questions about Lights-Out on all Windows platforms are answered here
eliu001
Beitrag von eliu001 »
Hello!
Been using all versions of Lights-Out for a number of years. Currently using version 3 on Windows 10 set up as a media server. Settings are to wake the server at a specific time of day, and monitor clients to remain on. Wake server with client activity is disabled, so it stayed off/hibernated when clients are turned on. I was also able to put the server to sleep manually, and it would stay off once done so regardless of client status. I recently upgraded the boot drive from a SATA SSD to NVMe and added a couple more storage drives. Since the upgrade, the server no longer remains asleep when connected clients are turned on. Furthermore, on my computer I no longer am able to trigger "Save energy now", which now says "Save energy now (Forbidden for this device)".
Something similar happened when Lights Out v3 was released and the server automatically updated from v2. I was able to fix things by uninstalling/reinstalling on the server, but that didn't work this time. I also uninstalled/reinstalled on the clients, to no avail.
I am using, and always have used, Lights Out in Community Edition mode. Let me know if there's anything else you need in order to diagnose and solve the issue. Thank you!
Re: Server behavior changed after hardware upgrade
let's start with issue 1: unexpected wake-up. Please verify your network card settings. Wake by pattern match should be disabled! Please see here for more details https://www.green-it-software.com/help/ ... ts_nic.htm
Issue 2: Open Lights-Out Console, double click the client computer and enable server actions.
Regards
eliu001
Hello Martin - thank you for responding!
Issue 1 resolved with the info at the link you provided!
Issue 2 is still ongoing - I cannot check "allow server actions" because the box is grayed out, stating "This functionality is not available in the community edition". This is the case on both of my client computers - mine and my wife's. While the "Save energy now" option is disabled on my computer (says "Save energy now (Forbidden for this device)"), my wife's computer has the "Save energy now" command active.
Thank you again!
To handle issue 2 please right click the bulb icon on your client computer. Then click settings and enable server wake-up.
The community edition does not have centralized management, so you have to configure this on each client.
Regards
eliu001
I do not see a "enable server wake-up" option in the Settings on my computer.
I want to be able to wake and sleep the server on-demand, outside of the scheduled powered-on period. I had this ability prior to the server hardware upgrade.
Thanks for all the help!
You see it on the left, on top. It's not enabled...
"Automatically wake server"
eliu001
I don't want "Automatically wake server" enabled. I want the server to stay off when clients are turned on outside of scheduled times. That was fixed with the article you linked earlier. What I want is to be able to sleep the server on-demand. You can see that function is disabled in the screen shot ("Save energy now"). It was working on my computer before the upgrade, and still works on my wife's computer. Is this fixable?
Thanks!
JoachimL
Beitrag von JoachimL »
Lights-Out just knows who is the real boss.. ;)
Joachim
Oh, sorry I missed it. That's a bug and get's fixed in 3.0.2.
In the meantime you can fix it yourself. Open services and stop the "Lights-Out 3 Client service". Then edit the file C:\ProgramData\LightsOut3Client\data\DeviceInfo.json. I recommend to use notepad ++ because you need administrative rights to write the file back.
Change the second line from
"allowserveractions": false,
to
"allowserveractions": true,
then save the file and restart the service.
Regards
eliu001
Thank you for the info, Martin! I think I will wait for the v3.0.2 update to fix the issue.
Here's a preview build of 3.0.2 with the fix: https://www.green-it-software.com/downl ... 2.4448.exe
