Hi.
I'm running 3.0.1.4433 and before I upgraded from version 2.5.2 I did not have that very many Resume [Unkonown] as i have now. I believe almost every resume is unknown. It even register it as unknown when the server is resuming from a regular Windows PC starting up. Is this some kind of regression from previous version?
Thanks.
Resume [Unkonown]
Re: Resume [Unkonown]
Hi, are you sure that you have seen a valid wake-up reason in version 2.x?
The wake-up reason is not always logged by Windows. This may be a shortcoming of drivers and/or Bios.
You can try to verify that yourself. Open a cmd.exe with administrative rights and enter
powercfg /lastwake
If that reports a valid device or reason, then Lights-Out should do also.
Regards
powercfg /lastwake
Regards
hakank22
Ok make sense. I think some Win update changed something...
