Console issue?
Problems or questions about Lights-Out on all Windows platforms are answered here
gaking
Console issue?
Beitrag von gaking »
Hi
I've just upgraded from version 2 to version 3.0.0.4424 and have tried changing host names in the network devices section of the console, however it does not appear to save them at all (neither using apply nor ok works within manage devices -> view device properties). It worked fine with v2?
It's running on Server Essentials 2016.
Re: Console issue?
Hi gaking,
are you talking about network devices or computers? Are you using the console or Dashboard?
Regards
gaking
Re: Console issue?
Hi
I've tried it from the Console (including running as an Administrator) and the Server Essentials Dashboard - same behaviour. It's the network devices tab.
Re: Console issue?
Thanks, I was able to replicate the issue.
Will publish a test version with a fix tomorrow.
Thanks for reporting
