2 clients back up unsuccessful
Problems or questions about Lights-Out 2 on all Windows platforms are answered here
TNR27
Beitrag von TNR27 »
I have four clients all was working well until 3 weeks ago when two of the clients keep failing to back up.
Re: 2 clients back up unsuccessful
Can you please give a little bit more background information? What kind of backup, which server os etc.
Can you run a manual backup?
Regards
TNR27
Beitrag von TNR27 »
WHS 2011, not able to perform manual backup.
TNR27
Beitrag von TNR27 »
Clients running windows 10, I have just determined if I customize the backup and remove the system drive (c:) the back up will run successfully. But once added back in, the back will fail.
Try to run a chkdsk on volume c: and have a look at eventlog for additional information why the backup fails.
TNR27
Beitrag von TNR27 »
Sorry not very tech savvy, can you provide details on how to accomplish this?
JoachimL
Beitrag von JoachimL »
Let me first say that this is obviously not a problem of LightsOut but of WHS client backup. You cannot expect Martin to support WHS client backup.
Having said that, open properties of drive C: in windows explorer and on the tools tab there is check button.
Best Regards,
Joachim
