Hi, Martin
I have been using Wake-On-Lan Proxy with Raspberry Pi 3 (Version 1.0.3) for successfully for over a year. However, I want to use in on a Pi Zero W so I can free up the Pi 3.
I doesn't seem to work with Pi Zero W or on another Pi Zero. Neither will port forward to any computer. Is this a known issue?
Thanks,
Bob Smith
Wake-On-Lan Proxy with Raspberry Pi Zero W
BSmith7760
Re: Wake-On-Lan Proxy with Raspberry Pi Zero W
Hi Bob, I do not have a Pi Zero W at hand, so I can only guess: Is WLAN connected all the time?
Can you please attach the log file?
BSmith7760
Hi, Martin
I started from scratch and built an SD card from scratch and now the Pi Zero W works fine.
Thanks for the software - it allows me to remotely Wake-on-Wan...
Thanks, again
Bob
Thanks, again
Bob
Good to know it's working on a Pi Zero.
Thanks for your feedback.
Regards
Regards
