WHS 2011
imeuzwa
WHS 2011
Having recently re-installed my WHS 2011 I would like to install "lightsout" addin on my Server. Bit puzzled by the .exe file available as the "lightsout" download for WHS, ie not a wmxx addin file, but tried to run this from the dashboard (within the server I though) as the instructions suggested. However it just installs on the client computer Windows 10 as if that's the server. I am I missing something here or do I need to run the download from the Server with no clients connected perhaps?
Re: WHS 2011
Please uninstall it from your W10 machine. Then use remote desktop to connect to your server. Install Lights-Out there. After that, you can use the Dashboard to manage the server and Lights-Out.
