Nabend zusammen,
hat jemand von euch Funambol und Smartermail am Laufen?
Ich habe schon mein Log-File im Smartermail-Forum gepostet, jedoch ohne Erfolg. Ihr seid meine letzte Hoffnung.
Auf dem SM-Server habe ich einen Nutzer eingerichtet. Die Synchronisation von Outlook klappt bestens.
Smartermail Free 6.5, Funambol 0.91, Thunderbird 2.0.0.23, Win7 HP/XP Prof
Bastian
Hier das Log-file:
2009-11-09 22:22:03 GMT +1:00 - # Funambol Mozilla Sync Client Log
22:22:03 GMT +1:00 [DEBUG] - Creating SyncSources...
22:22:03 GMT +1:00 [DEBUG] - [contact] ContactSyncSource(): Contact folder: "abook.mab"
22:22:03 GMT +1:00 [DEBUG] - [contact] ContactSyncSource(): Contact folder found: "Persönliches Adressbuch"
22:22:03 GMT +1:00 [DEBUG] - [event] CalendarSyncSource(): Calendar folder: "moz-profile-calendar://?id=2"
22:22:03 GMT +1:00 [DEBUG] - [event] CalendarSyncSource(): Calendar found: 'Scal'
22:22:03 GMT +1:00 [DEBUG] - [task] CalendarSyncSource(): Calendar folder: "moz-profile-calendar://?id=2"
22:22:03 GMT +1:00 [DEBUG] - [task] CalendarSyncSource(): Calendar found: 'Scal'
22:22:03 GMT +1:00 [INFO] - Checking for contact sync...
22:22:03 GMT +1:00 [INFO] - The source contact isn't set to be synced
22:22:03 GMT +1:00 [INFO] - Checking for event sync...
22:22:03 GMT +1:00 [INFO] - Required sync mode: 'two way sync'
22:22:03 GMT +1:00 [INFO] - Checking for task sync...
22:22:03 GMT +1:00 [INFO] - The source task isn't set to be synced
22:22:03 GMT +1:00 [DEBUG] - Set the synchronization listeners
22:22:03 GMT +1:00 [INFO] - --------------------> Begin SyncML Synchronization <--------------------
22:22:03 GMT +1:00 [DEBUG] - Synchronization URL: http://ipwhs:9998/sync/default.aspx
22:22:03 GMT +1:00 [INFO] - Preparing synchronization of event...
22:22:03 GMT +1:00 [DEBUG] - Checking devinfo...
22:22:03 GMT +1:00 [DEBUG] - devinfo hash: UO1vdWiXJWaiKKS7pYus1g==
22:22:03 GMT +1:00 [DEBUG] - devinfo changed, retransmit
22:22:03 GMT +1:00 [DEBUG] - Initialization message:
22:22:03 GMT +1:00 [DEBUG] - User Agent = Funambol Mozilla Sync Client v0.9.1
22:22:03 GMT +1:00 [DEBUG] - <?xml version="1.0" encoding="UTF-8"?>
<SyncML>
<SyncHdr><VerDTD>1.2</VerDTD>
<VerProto>SyncML/1.2</VerProto>
<SessionID>1257801723</SessionID>
<MsgID>1</MsgID>
<Target><LocURI>http://ipwhs:9998/sync/default.aspx</LocURI>
</Target>
<Source><LocURI>fmz-tc18VgyvFgsJlqvK1oGIoA==</LocURI>
</Source>
<Cred><Meta><Format xmlns="syncml:metinf">b64</Format>
<Type xmlns="syncml:metinf">syncml:auth-basic</Type>
</Meta>
<Data>YmFzdGlhbkBtYWlsLmRlOmJrOnNkbDAw</Data>
</Cred>
<Meta><MaxMsgSize xmlns="syncml:metinf">250000</MaxMsgSize>
</Meta>
</SyncHdr>
<SyncBody><Alert><CmdID>1</CmdID>
<Data>200</Data>
<Item><Target><LocURI>scal</LocURI>
</Target>
<Source><LocURI>event</LocURI>
</Source>
<Meta><Anchor xmlns="syncml:metinf"><Last>0</Last>
<Next>1257801723</Next>
</Anchor>
</Meta>
</Item>
</Alert>
<Put><CmdID>2</CmdID>
<Meta><Type xmlns="syncml:metinf">application/vnd.syncml-devinf+xml</Type>
</Meta>
<Item><Source><LocURI>./devinf12</LocURI>
</Source>
<Data><DevInf xmlns="syncml:devinf"><VerDTD>1.2</VerDTD>
<Man>Funambol</Man>
<SwV>0.9.1</SwV>
<DevID>fmz-tc18VgyvFgsJlqvK1oGIoA==</DevID>
<DevTyp>workstation</DevTyp>
<UTC/><DataStore><SourceRef>contact</SourceRef>
<Rx-Pref><CTType>text/x-vcard</CTType>
<VerCT>2.1</VerCT>
</Rx-Pref>
<Tx-Pref><CTType>text/x-vcard</CTType>
<VerCT>2.1</VerCT>
</Tx-Pref>
<CTCap><CTType>text/x-vcard</CTType>
<VerCT>2.1</VerCT>
<Property><PropName>BEGIN</PropName>
<PropParam><ParamName>VCARD</ParamName>
</PropParam>
</Property>
<Property><PropName>VERSION</PropName>
<PropParam><ParamName>2.1</ParamName>
</PropParam>
</Property>
<Property><PropName>N</PropName>
</Property>
<Property><PropName>FN</PropName>
</Property>
<Property><PropName>NICKNAME</PropName>
</Property>
<Property><PropName>TEL</PropName>
<PropParam><ParamName>HOME</ParamName>
</PropParam>
</Property>
<PropParam><ParamName>WORK</ParamName>
</PropParam>
</Property>
<PropParam><ParamName>CELL</ParamName>
</PropParam>
</Property>
<PropParam><ParamName>PAGER</ParamName>
</PropParam>
</Property>
<PropParam><ParamName>FAX</ParamName>
</PropParam>
</Property>
<Property><PropName>EMAIL</PropName>
<PropParam><ParamName>INTERNET</ParamName>
</PropParam>
</Property>
</PropParam>
</PropParam>
</Property>
</PropParam>
</PropParam>
<PropParam><ParamName>X-FUNAMBOL-INSTANTMESSENGER</ParamName>
</PropParam>
</Property>
<Property><PropName>ADR</PropName>
</Property>
</PropParam>
</Property>
</PropParam>
</Property>
<Property><PropName>ORG</PropName>
</Property>
<Property><PropName>TITLE</PropName>
</Property>
<Property><PropName>URL</PropName>
</PropParam>
</Property>
</PropParam>
</Property>
<Property><PropName>BDAY</PropName>
</Property>
<Property><PropName>NOTE</PropName>
</Property>
<Property><PropName>END</PropName>
</PropParam>
</Property>
</CTCap>
<SyncCap><SyncType>2</SyncType>
<SyncType>1</SyncType>
<SyncType>6</SyncType>
<SyncType>4</SyncType>
</SyncCap>
</DataStore>
<DataStore><SourceRef>event</SourceRef>
<Rx-Pref><CTType>text/calendar</CTType>
<VerCT>2.0</VerCT>
</Rx-Pref>
<Tx-Pref><CTType>text/calendar</CTType>
<VerCT>2.0</VerCT>
</Tx-Pref>
</SyncCap>
</DataStore>
<DataStore><SourceRef>task</SourceRef>
<VerCT>2.0</VerCT>
</Rx-Pref>
<VerCT>2.0</VerCT>
</Tx-Pref>
</SyncCap>
</DataStore>
</DevInf>
</Data>
</Item>
</Put>
<Final/></SyncBody>
</SyncML>
22:22:03 GMT +1:00 [DEBUG] - Connecting to ipwhs:9998
22:22:03 GMT +1:00 [DEBUG] - Requesting resource /sync/default.aspx
22:22:03 GMT +1:00 [DEBUG] - Message sent
22:22:03 GMT +1:00 [DEBUG] - Data sent succesfully to server. Server responds OK
22:22:03 GMT +1:00 [DEBUG] - Header: HTTP/1.1 200 OK
Date: Mon, 09 Nov 2009 21:22:05 GMT
Server: Microsoft-IIS/6.0
X-Powered-By: ASP.NET
X-AspNet-Version: 2.0.50727
Set-Cookie: ASP.NET_SessionId=2hr4x1zwy4pi3i55atgfuzy3; path=/; HttpOnly
Cache-Control: private
Content-Type: application/vnd.syncml+xml
Content-Length: 1079
22:22:03 GMT +1:00 [DEBUG] - Reading response...
22:22:03 GMT +1:00 [DEBUG] - Content-length: 1079
22:22:03 GMT +1:00 [DEBUG] - Response read:
<?xml version="1.0" encoding="UTF-8" ?><SyncML><SyncHdr><VerDTD>1.2</VerDTD><VerProto>SyncML/1.2</VerProto><SessionID>1257801723</SessionID><MsgID>1</MsgID><Target><LocURI>fmz-tc18VgyvFgsJlqvK1oGIoA==</LocURI></Target><Source><LocURI>http://ipwhs:9998/sync/default.aspx</Lo ... ta><Format xmlns="syncml:metinf">b64</Format><Type xmlns="syncml:metinf">syncml:auth-basic</Type></Meta></Chal><Data>401</Data></Status><Status><CmdID>2</CmdID><MsgRef>1</MsgRef><CmdRef>1</CmdRef><Cmd>Alert</Cmd><TargetRef>scal</TargetRef><SourceRef>event</SourceRef><Data>401</Data></Status><Status><CmdID>3</CmdID><MsgRef>1</MsgRef><CmdRef>2</CmdRef><Cmd>Put</Cmd><SourceRef>./devinf12</SourceRef><Data>401</Data></Status><Final/></SyncBody></SyncML>
22:22:03 GMT +1:00 [ERROR] - Error in preparing sync: Client not authenticated
22:22:03 GMT +1:00 [DEBUG] - ===========================================================
================ SYNCHRONIZATION REPORT ===============
Last error code = 401
Last error msg = Client not authenticated
----------|--------CLIENT---------|--------SERVER---------|
Source | NEW | MOD | DEL | NEW | MOD | DEL |
contact| 0/ 0| 0/ 0| 0/ 0| 0/ 0| 0/ 0| 0/ 0|
event| 0/ 0| 0/ 0| 0/ 0| 0/ 0| 0/ 0| 0/ 0|
task| 0/ 0| 0/ 0| 0/ 0| 0/ 0| 0/ 0| 0/ 0|
contact:
Source State = 0
Last error code = 0
Last error msg = (null)
event:
Source State = 0
Last error code = 0
task:
Source State = 0
Last error code = 0
22:22:03 GMT +1:00 [INFO] - --------------------> End SyncML Synchronization <--------------------
22:22:03 GMT +1:00 [DEBUG] - Saving configuration settings...
22:22:03 GMT +1:00 [DEBUG] - Saving configuration...
22:22:03 GMT +1:00 [DEBUG] - Writing configuration settings to the management tree
22:22:03 GMT +1:00 [DEBUG] - Configuration saved.
22:22:04 GMT +1:00 [DEBUG] - Unset listeners
real_Bigdaddy
Bastian
Mein Homeserver: Acer Aspire easyStore H340 mit 2 TB
Clients: 2x Win 7 und Win XP intern, 2 x Win XP per VPN
Mein Technikblog: http://bastiankowalek.wordpress.com/
Bastian
