Server wacht nicht auf
Hi
Ich hab auf Win7 Ultimate(64bit) umgestellt doch wenn ich starte wacht der Server nicht auf.
Der Dienst von Lights Out steht auf Automatisch
Hier mal die Log Datei von heute
2009-10-24 10:13:27.0916 LightsOutClientService [1] Logging started, LightsOutClientService Version 0.8.2.235
2009-10-24 10:13:27.0916 LightsOutClientService [1] Log cleanup LightsOutClientService.*.log:0
2009-10-24 10:13:27.1852 LightsOutClientService [1] LAN-Verbindung: IP Address 192.168.178.43
2009-10-24 10:13:27.1852 LightsOutClientService [1] Server IP Address 192.168.178.3
2009-10-24 10:13:27.1852 LightsOutClientService [1] Read Server MAC = 00-1C-C4-39-CD-74
2009-10-24 10:13:27.2320 LightsOutClientService [6] Service should start
2009-10-24 10:13:27.2320 LightsOutClientService [6] Service started
2009-10-24 10:13:27.2320 LightsOutClientService [4] WolThread started
2009-10-24 10:13:31.4596 LightsOutClientService [4] sendWakeUp: NetworkAvailable=True, Interval=240
2009-10-24 10:13:31.4596 LightsOutClientService [4] WakeUp
2009-10-24 10:13:31.6000 AxoNet.LightsOut.WakeOnLan [4] sending magic packet to 192.168.178.255:12287
2009-10-24 10:13:31.6000 LightsOutClientService [4] Sent WOL packet(s) to server with MAC = 00-1C-C4-39-CD-74
2009-10-24 10:13:34.7824 LightsOutClientService [4] >> Server is down
2009-10-24 10:13:34.7824 LightsOutClientService [4] PrepareWakeUp
2009-10-24 10:13:39.0100 LightsOutClientService [4] sendWakeUp: NetworkAvailable=True, Interval=5
2009-10-24 10:13:39.0100 LightsOutClientService [4] WakeUp
2009-10-24 10:13:39.1036 AxoNet.LightsOut.WakeOnLan [4] sending magic packet to 192.168.178.255:12287
2009-10-24 10:13:39.1036 LightsOutClientService [4] Sent WOL packet(s) to server with MAC = 00-1C-C4-39-CD-74
2009-10-24 10:13:42.2860 LightsOutClientService [4] >> Server is down
2009-10-24 10:13:42.2860 LightsOutClientService [4] PrepareWakeUp
2009-10-24 10:13:51.5836 LightsOutClientService [4] sendWakeUp: NetworkAvailable=True, Interval=10
2009-10-24 10:13:51.5836 LightsOutClientService [4] WakeUp
2009-10-24 10:13:51.7336 AxoNet.LightsOut.WakeOnLan [4] sending magic packet to 192.168.178.255:12287
2009-10-24 10:13:51.7336 LightsOutClientService [4] Sent WOL packet(s) to server with MAC = 00-1C-C4-39-CD-74
2009-10-24 10:13:54.8556 LightsOutClientService [4] >> Server is down
2009-10-24 10:13:56.5856 LightsOutClientService [4] PrepareWakeUp
2009-10-24 10:14:10.9000 LightsOutClientService [4] sendWakeUp: NetworkAvailable=True, Interval=20
2009-10-24 10:14:10.9000 LightsOutClientService [4] WakeUp
2009-10-24 10:14:11.0248 AxoNet.LightsOut.WakeOnLan [4] sending magic packet to 192.168.178.255:12287
2009-10-24 10:14:11.0248 LightsOutClientService [4] Sent WOL packet(s) to server with MAC = 00-1C-C4-39-CD-74
2009-10-24 10:14:14.2072 LightsOutClientService [4] >> Server is down
2009-10-24 10:14:14.2072 LightsOutClientService [4] PrepareWakeUp
2009-10-24 10:14:38.4494 LightsOutClientService [4] sendWakeUp: NetworkAvailable=True, Interval=40
2009-10-24 10:14:38.4494 LightsOutClientService [4] WakeUp
2009-10-24 10:14:38.5898 AxoNet.LightsOut.WakeOnLan [4] sending magic packet to 192.168.178.255:12287
2009-10-24 10:14:38.5898 LightsOutClientService [4] Sent WOL packet(s) to server with MAC = 00-1C-C4-39-CD-74
2009-10-24 10:14:41.7594 LightsOutClientService [4] >> Server is down
2009-10-24 10:14:41.7594 LightsOutClientService [4] PrepareWakeUp
Re: Server wacht nicht auf
Was ist das für ein WHS ? Hast du WOL auf der NIC des WHS freigegeben ?
Der server ist ein HP ProLiant mit nem Pentium D 940 und 4GB Ram
Bei allen anderen Rechnern wacht der Server auf sodass ich denke das Prob liegt bei mir
Weiß denn keiner eine Antwort?
once again ...Nobby1805 hat geschrieben:Hast du WOL auf der NIC des WHS freigegeben ?
und ... stimmen IP- udn MAC-Adresse im Log mit den Adressen deines Servers überein ??
Moin zusammen,
ich klinke mich hier mal ein, weil ich das gleiche Problem habe.
@Thunnes: Du hast Dein Problem recht mager beschrieben. Da fällt die Fehlersuche schwer. Also mal Schritt für Schritt.
WOL muß nicht nur im Bios aktiviert sein, sondern auch in der Systemsteuerung des WHS unter Netzwerkgeräte. Dort gibt es bei mir einen Button "Konfigurieren" (nVidia ION). In diesen Einstellungen findet man meist mehrere "Wake on ..." Optionen, wie z.B. Lan, PME (Power Management Event) o.Ä.
Dann solltest Du erstmal probieren, dass es in Deinem lokalen Netzwerk funktioniert. Lies die MAC Adresse des WHS mit "ipconfig[blank]/all in einem DOS Konsole aus. Google nach wolgui und lad Dir das Programm auf den PC. Erfordert keine Installation. Im Router muß der Port 9 an die IP des WHS weiter geleitet sein.
Ebenfalls ist zu beachten, dass es aus dem Lokalen Netz klappen kann, aber nicht über das Internet von außen, da z.B. mein Router (Netgear WGR614 v9) das unterbindet. Alle Anleitungen aus dem Internet, die das umgehen sollen, habe ich ausprobiert - geht aber nicht. Von Intern kann ich den WHS aus dem Standby und aus dem Heruntergefahrenen Zustand wecken, von außen nur aus dem Standby. Leider verstehe ich das nicht ganz.
Sag mal bescheid, ob's klappt.
Grüße, Mick
Grüße, Mick
Desktop: ASRock Z97E-ITX/ac in vollpassivem Gehäuse Straecom FC8 B Evo - i7-4790 - 1 x 2,5" Samsung SSD Pro 850, 256GB - 1 x 2,5" Samsung SSD Pro 850, 500GB
(Es ist endlich leise, weil sich NICHTS mehr bewegt!)
WHS 2011: Intel DH67CF - Intel i5-2400S - 4GB DDR3 1333MHz 1 x 2.5" Samsung SSD 830 - 3 x 3.5" Samsung HD154UI Idle: 30W
Wenn es von anderen Rechnern klappt
und alle Rechner im gleichen Netzwerk sind (Verbindung über LAN nicht Internet)
und die MAC und die IP aus dem Log passen,
dann müsste es an der Firewall liegen, welche das WOL Signal blockt.
Wenn MAC und IP nicht passen, wird das Signal an den falschen Empfänger geschickt.
Hast du evtl. mehrere Netzwerkkarten aktiv?
MAC und IP-Adresse stimmen definitiv, habe ich tausend mal geprüft. Server hat nur eine Netzwerkkarte und alle anderen Rechner sind aus. (hardwaremäßig mit Steckerleiste)
In der Firewall ist der Port 9 an die IP des Home Servers weitergeleitet - trotzdem funktioniert es nicht.
Der Rechner hat aber auch im heruntergefahrenen Zustand keine IP. Ich kapier nicht, wie es funktionieren soll.
Das Protokoll des Routers sagt:
[Lan access from Remote] from
xxx.xxx.xxx.xxx:xxxxx to 192.168.xxx.xxx:9
Montag, Okt 26, 2009 19:22:10
Das Magic Packet kommt also an, aber was macht der Router damit?
Grüße, Mick
Grüße, Mick
Einklink!
Wär mir neu, dass man in die Firewall ein Portloch 9 öffnen muss, um im LAN ein Wol zu erreichen.....Hatte ich jedenfalls noch nie.
Der Grund, warum der WOL von außen auf einen Standby-Rechner (WHS) klappt, könnte sein, dass er seine IP noch im Gedächtnis behält. Bei allen anderen Schlafzuständen eben nicht mehr.
Wenn der Router einen Broadcast nicht weiterleitet oder zulässt, sehe ich wenig Chancen den WHS über einen geregelten WOL von außen zu wecken....
Falls der WHS ein Eigenbau ist, bestünde noch die Möglichkeit ein Aufwecken via Modem oder Faxkarte zu erreichen, bei dem der Server dann aufwacht, wenn er einen Anruf bekommt.....
Weitere, aber teure Möglichkeit wäre noch eine Steckdosenleiste mit Lan-Anschluss.....
Zuletzt geändert von steve0564 am 28. Okt 2009, 12:48, insgesamt 1-mal geändert.
LG
Steve
Router: FritzBox 7270
Giglan, Cat7
Steve
Giglan, Cat7
....wieseo Port 9 Schließen???
Ich hab doch geschrieben, dass er offen (weitergeleitet) ist.
Grüße, Mick
Grüße, Mick
Ein WOL Paket wird nicht an eine IP Adresse geschickt.
Es wird vielmehr an einen Subnet-Bereich geschickt. Dadurch wird dies von allen Rechnern im Netz empfangen. Anhand der mitgesendeten MAC-Adresse erkennt die Netzwerkkarte ob sie gemeint ist.
Und diese Weiterleitung an alle Rechner wird von vielen Routern nicht angeboten. Eine Weiterleitung an eine IP-Adresse geht nur, wenn der Rechner angeschaltet ist. Was bei WOL natürlich keinen Sinn macht.
Firewallseitig muss normalerweise nur ggf. beim Client etwas geändert werden. Bei dem ausgeschalteten Rechner wirkt keine lokale Firewall, da die Netzwerkkarte generell erst einem alles aufnimmt.
Ich meinte schon "schießen". Das war kein Schreibfehler! Habs aber trotzdem klarer gestellt!Ing.Wolf hat geschrieben:....wieseo Port 9 Schließen???
Grüße, Mick
LG
Steve
Giglan, Cat7
Steve
Giglan, Cat7
