PS3 Media server findet Playstation nicht
semmi
Beitrag von semmi »
Hilfe
habe den PSE Server gerade installiert, findet aber die PS3 nicht.
LOG
[main] TRACE 11:33:52.346 Starting Java PS3 Media Server v1.10.51
[main] TRACE 11:33:52.347 by shagrath / 2008-2009
[main] TRACE 11:33:52.347 http://ps3mediaserver.blogspot.com
[main] TRACE 11:33:52.347 http://code.google.com/p/ps3mediaserver
[main] TRACE 11:33:52.348
[main] TRACE 11:33:52.348 Java 1.6.0_13-Sun Microsystems Inc.
[main] TRACE 11:33:52.348 OS Windows Vista x86 6.0
[main] TRACE 11:33:52.348 Encoding: Cp1252
[main] TRACE 11:33:52.348 Temp folder: C:\Users\Klement\AppData\Local\Temp\javaps3media
[main] TRACE 11:33:52.349 Found AviSynth plugins dir: C:\Program Files\AviSynth 2.5\plugins
[main] TRACE 11:33:52.351 Found VideoLAN version 0.9.9 at: C:\Program Files\VideoLAN\VLC\vlc.exe
[main] TRACE 11:33:52.437 Registering transcoding engine AviSynth/FFmpeg
[main] TRACE 11:33:52.438 Registering transcoding engine FFmpeg Audio
[main] TRACE 11:33:52.453 Registering transcoding engine MEncoder
[main] TRACE 11:33:52.454 Registering transcoding engine Avisynth/MEncoder
[main] TRACE 11:33:52.455 Registering transcoding engine MPlayer Audio
[main] TRACE 11:33:52.456 Registering transcoding engine MEncoder Web
[main] TRACE 11:33:52.457 Registering transcoding engine MPlayer Video Dump
[main] TRACE 11:33:52.459 Registering transcoding engine MPlayer Web
[main] TRACE 11:33:52.464 Registering transcoding engine TsMuxer
[main] TRACE 11:33:52.465 Registering transcoding engine Audio High Fidelity
[main] TRACE 11:33:52.466 Registering transcoding engine VideoLan Audio Streaming
[main] TRACE 11:33:52.467 Registering transcoding engine VideoLan Video Streaming
[main] TRACE 11:33:52.467 Registering transcoding engine FFmpeg DVR-MS Remux
[main] TRACE 11:33:52.468 Registering transcoding engine Raws Thumbnailer
[main] TRACE 11:33:52.977 Scanning network interface lo / Software Loopback Interface 1
[main] TRACE 11:33:52.982 Scanning network interface net0 / WAN-Miniport (L2TP)
[main] TRACE 11:33:52.986 Scanning network interface net1 / WAN-Miniport (PPTP)
[main] TRACE 11:33:52.991 Scanning network interface ppp0 / WAN-Miniport (PPPOE)
[main] TRACE 11:33:52.996 Scanning network interface eth0 / WAN-Miniport (IPv6)
[main] TRACE 11:33:53.001 Scanning network interface eth1 / WAN-Miniport (IP)
[main] TRACE 11:33:53.007 Scanning network interface ppp1 / Asynchroner RAS-Adapter
[main] TRACE 11:33:53.011 Scanning network interface eth2 / VIA Rhine II-kompatibler Fast-Ethernet-Adapter
[main] TRACE 11:33:53.016 Using address /192.168.99.100 found on network interface: name:eth2 (VIA Rhine II-kompatibler Fast-Ethernet-Adapter) index: 8 addresses: /192.168.99.100; /192.168.2.24;
[main] TRACE 11:33:53.017 Created socket: /192.168.99.100:5001
[Thread-5] TRACE 11:33:53.023 Starting DLNA Server on host 192.168.99.100 and port 5001...
[main] TRACE 11:33:53.026 Sending ALIVE...
[main] TRACE 11:33:53.063 Using following UUID: ccbb506a-d82b-320d-81c1-b3e341ff176c
[main] TRACE 11:33:58.125 It's ready! You should see the server appears on XMB
[Thread-8] TRACE 11:34:08.125 Sending ALIVE...
[Thread-8] TRACE 11:34:33.798 Sending ALIVE...
[AWT-EventQueue-0] TRACE 11:34:48.076 (Neu)Installation Win32-Dienst
[AWT-EventQueue-0] TRACE 11:34:48.447 Process C:\Program Files\PS3 Media Server\win32\service\wrapper.exe has a return code of 1! Maybe an error occured... check the log file
[Thread-8] TRACE 11:37:37.324 Sending ALIVE...
[Thread-8] TRACE 11:40:42.527 Sending ALIVE...
[Thread-8] TRACE 11:43:47.791 Sending ALIVE...
[Thread-8] TRACE 11:46:51.537 Sending ALIVE...
Kann mir jemand helfen ???
Buwser
Re: PS3 Media server findet Playstation nicht
Beitrag von Buwser »
Hi Semmi
Hast du den PS3 Media Server in der Firewall freigegeben?
Schau mal hier: viewtopic.php?f=30&t=4158 nach, weiter unten.
Buwser
schulle
Beitrag von schulle »
ich nutze seid einiger Zeit den Java PS3 Media Server v1.10.51
Anfangs hat auch alles wunderbar geklappt aber von heute auf morgen finden sich die beiden auf einmla nicht mehr. Verbindung zum Router hat die PS3 noch da ich auch weiterhin ins Internet komme. Der PC ist ebenfalls noch weiterhin im Internet.
Habe sogar den Media Server neu installiert aber nichts hilft. Hoffe ihr könnt mir vielleicht helfen.
Gruß Schulle
