Seit 2 Tagen bleibt mein WHS wach Trots LightOut
m3Sa
Beitrag von m3Sa »
Hallo Leute,
ich benutze LightsOut schon seit einigen Wochen, doch die letzten Tage lief er einfach weiter :(
Hier einen auszug der Log wo er noch in StandBy ging vom 24.06:
2008-06-24 22:00:02.9687 [5]  ClientActive=False, BackupRunning=False, InBackupTime=False, InTimeSpan=True, Action=Suspend/Suspend
2008-06-24 22:00:02.9687 [5]  ClientActive=False, BackupRunning=False, InBackupTime=False, InTimeSpan=False, Action=Suspend/Suspend
2008-06-24 22:00:02.9687 [5]   CheckAction: a=Suspend/Suspend force=False IsInStandby=False
2008-06-24 22:00:02.9687 [5]   >>> Suspend <<<
2008-06-24 22:00:02.9843 [5] + HandleServices: DriveExtenderMigrator Status=Running
2008-06-24 22:00:02.9843 [5]  < stopping DriveExtenderMigrator
2008-06-24 22:00:04.0000 [5]  < service DriveExtenderMigrator Status=StopPending
2008-06-24 22:00:05.0000 [5]  < service DriveExtenderMigrator Status=Stopped
und am Tag danach 25.06:
2008-06-25 22:00:30.8437 [5]  ClientActive=False, BackupRunning=False, InBackupTime=False, InTimeSpan=False, Action=Suspend/Suspend
2008-06-25 22:00:30.8593 [5]  ClientActive=True, BackupRunning=False, InBackupTime=False, InTimeSpan=False, Action=Suspend/Suspend
2008-06-25 22:15:15.8593 [5]  ClientActive=True, BackupRunning=False, InBackupTime=False, InTimeSpan=False, Action=Suspend/Suspend
2008-06-25 22:15:15.8593 [5]  ClientActive=False, BackupRunning=False, InBackupTime=False, InTimeSpan=False, Action=Suspend/Suspend
2008-06-25 22:15:15.8593 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-06-25 22:15:30.8593 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-06-25 22:15:45.8593 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-06-25 22:16:00.8593 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-06-25 22:16:15.8593 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-06-25 22:16:30.8593 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-06-25 22:16:45.8593 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-06-25 22:17:00.8593 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-06-25 22:17:15.8593 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-06-25 22:17:30.8593 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-06-25 22:17:45.8593 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-06-25 22:18:00.8593 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-06-25 22:18:15.8593 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-06-25 22:18:30.8593 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-06-25 22:18:45.8593 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
die ganze Nacht die Meldung weiter...
Dann kommt Backuptime...
2008-06-26 00:59:26.2656 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-06-26 00:59:41.2656 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-06-26 00:59:56.2656 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-06-26 01:00:11.2656 [5]  ClientActive=False, BackupRunning=False, InBackupTime=False, InTimeSpan=False, Action=Suspend/Suspend
2008-06-26 01:00:11.2656 [5]  ClientActive=False, BackupRunning=False, InBackupTime=True, InTimeSpan=False, Action=Suspend/Suspend
2008-06-26 02:00:11.2656 [5]  ClientActive=False, BackupRunning=False, InBackupTime=True, InTimeSpan=False, Action=Suspend/Suspend
2008-06-26 02:00:11.2656 [5]  ClientActive=False, BackupRunning=False, InBackupTime=False, InTimeSpan=True, Action=Suspend/Suspend
2008-06-26 03:00:12.4843 [5]  ClientActive=False, BackupRunning=False, InBackupTime=False, InTimeSpan=True, Action=Suspend/Suspend
2008-06-26 03:00:12.5000 [5]  ClientActive=False, BackupRunning=False, InBackupTime=False, InTimeSpan=False, Action=Suspend/Suspend
2008-06-26 03:00:12.5000 [5]   CheckAction: a=Suspend/Suspend force=True IsInStandby=True
2008-06-26 03:00:27.5000 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-06-26 03:00:42.5000 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-06-26 03:00:57.5000 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-06-26 03:01:12.5156 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
und wieder weiter...
Wüsste nicht was ich an dem Vortag geändert habe, dass nichts mehr funst :(
Bin für jegliche Hilfe dankbar!
MfG
Carsten
Mainb. Intel DQ35MP
Proz. Intel Core2Quad Q6600
RAM GeIL 4GB DDR2-800 Kit
(System) gespiegelt 2x 1TB WD WD10EADS
(Ext. Sicherung) 1x 3TB WD
Win Server 2012 Essentials
- Lights Out
Re: Seit 2 Tagen bleibt mein WHS wach Trots LightOut
Mal bitte den Dienst LightsOut auf dem Server stoppen und dann neu starten.
Aus irgend einem Grund schlug der erste Standby fehl, LightsOut ist aber der Meinung dass der Standby noch andauert.
m3Sa
Beitrag von m3Sa »
Hey danke,
hab ich gleich mal gemacht ;)
Hätt ich auch selber drauf kommen können *gg*
Werd mich meld wenns problem noch weiter besteht!
MfG
Carsten
Mainb. Intel DQ35MP
- Lights Out
m3Sa
Beitrag von m3Sa »
Hey,
also ab und zu hängt sich der Dienst einfach auf!
Liegt es evtl daran, dass mein Server nie hoch und runter fährt?
Er geht bei mir nur innen StandBy.
MfG
Carstem
Mainb. Intel DQ35MP
- Lights Out
Wie äußert sich das Aufhängen? Ist der Dienst gestorben und kann neu gestartet werden?
- Was steht im Eventlog?
- Was steht im Logfile?
Meinen Server fahre ich mit LightsOut immer in den Standby. Ein Problem gab es da bisher nicht.
m3Sa
Beitrag von m3Sa »
Hey,
also die Logfiles werden wie beim 1. Beitrag weiter geschrieben, eben nur dass er nicht in StandBy geht.
Sobald ich den Dienst beende und wieder starte ist wieder alles i.O.
Hier die Auszüge vom Tag des Geschehens...
LightsOutService.2008-08-18.log:
2008-08-18 01:00:11.5625 [3] Power event: QuerySuspend
2008-08-18 01:00:11.9375 [4] Power event: Suspend
2008-08-18 01:00:12.3125 [8] Power event: ResumeAutomatic
2008-08-18 01:00:12.3125 [8] + HandleServices: DriveExtenderMigrator Status=Stopped
2008-08-18 01:00:12.3125 [8]  > starting DriveExtenderMigrator
2008-08-18 01:00:26.5625 [5] ----------------------------
2008-08-18 01:00:26.5625 [5] LightsOutService    : 0.7.6.101
2008-08-18 01:00:26.5625 [5] Aktion              : Suspend
2008-08-18 01:00:26.5625 [5] AlwaysOnDuringBackup: True
2008-08-18 01:00:26.5625 [5] BackupStartTime     : 01:00
2008-08-18 01:00:26.5625 [5] BackupEndTime       : 02:00
2008-08-18 01:00:26.5625 [5] ExcludedClients     :
2008-08-18 01:00:26.5625 [5] IsModified          : False
2008-08-18 01:00:26.5625 [5] DaysToShow          : 14
2008-08-18 01:00:26.5625 [5] ShowBackup          : False
2008-08-18 01:00:26.5625 [5] ShowServer          : True
2008-08-18 01:00:26.5625 [5] StartStopServices   : DriveExtenderMigrator
2008-08-18 01:00:26.5625 [5] WaitTime            : 15
2008-08-18 01:00:26.5625 [5] Client              : CARSTEN
2008-08-18 01:00:26.5625 [5] Client              : KLAUS
2008-08-18 01:00:26.5625 [5] Clients found       : 2(2)
2008-08-18 01:00:26.5781 [5]  ClientActive=False, BackupRunning=False, InBackupTime=False, InTimeSpan=False, Action=Suspend/Suspend
2008-08-18 01:00:26.5781 [5]  ClientActive=True, BackupRunning=False, InBackupTime=True, InTimeSpan=False, Action=Suspend/Suspend
2008-08-18 01:15:26.5781 [5]  ClientActive=True, BackupRunning=False, InBackupTime=True, InTimeSpan=False, Action=Suspend/Suspend
2008-08-18 01:15:26.5781 [5]  ClientActive=False, BackupRunning=False, InBackupTime=True, InTimeSpan=False, Action=Suspend/Suspend
2008-08-18 02:00:11.5781 [5]  ClientActive=False, BackupRunning=False, InBackupTime=True, InTimeSpan=False, Action=Suspend/Suspend
2008-08-18 02:00:11.5781 [5]  ClientActive=False, BackupRunning=False, InBackupTime=False, InTimeSpan=False, Action=Suspend/Suspend
2008-08-18 02:00:11.5781 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=False
2008-08-18 02:00:11.5781 [5]   >>> Suspend <<<
2008-08-18 02:00:11.5781 [5] + HandleServices: DriveExtenderMigrator Status=Running
2008-08-18 02:00:11.5781 [5]  < stopping DriveExtenderMigrator
2008-08-18 02:00:12.5781 [5]  < service DriveExtenderMigrator Status=StopPending
2008-08-18 02:00:13.5781 [5]  < service DriveExtenderMigrator Status=Stopped
2008-08-18 02:00:13.5937 [4] Power event: QuerySuspend
2008-08-18 02:00:28.5937 [5]  ClientActive=False, BackupRunning=False, InBackupTime=False, InTimeSpan=False, Action=Suspend/Suspend
2008-08-18 02:00:28.5937 [5]  ClientActive=True, BackupRunning=False, InBackupTime=False, InTimeSpan=False, Action=Suspend/Suspend
2008-08-18 02:15:13.5937 [5]  ClientActive=True, BackupRunning=False, InBackupTime=False, InTimeSpan=False, Action=Suspend/Suspend
2008-08-18 02:15:13.5937 [5]  ClientActive=False, BackupRunning=False, InBackupTime=False, InTimeSpan=False, Action=Suspend/Suspend
2008-08-18 02:15:13.5937 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-08-18 02:15:28.5937 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-08-18 02:15:43.5937 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-08-18 02:15:58.5937 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-08-18 02:16:13.6093 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-08-18 02:16:28.6093 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-08-18 02:16:43.6093 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-08-18 02:16:58.6093 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-08-18 02:17:13.6093 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-08-18 09:59:15.3750 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-08-18 09:59:30.3906 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-08-18 09:59:45.3906 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-08-18 10:00:00.3906 [5]  ClientActive=False, BackupRunning=False, InBackupTime=False, InTimeSpan=False, Action=Suspend/Suspend
2008-08-18 10:00:00.3906 [5]  ClientActive=False, BackupRunning=False, InBackupTime=False, InTimeSpan=True, Action=Suspend/Suspend
2008-08-18 15:23:30.4531 [5]  ClientActive=False, BackupRunning=False, InBackupTime=False, InTimeSpan=True, Action=Suspend/Suspend
2008-08-18 15:23:30.4531 [5]  ClientActive=True, BackupRunning=False, InBackupTime=False, InTimeSpan=True, Action=Suspend/Suspend
2008-08-18 22:00:00.5312 [5]  ClientActive=True, BackupRunning=False, InBackupTime=False, InTimeSpan=True, Action=Suspend/Suspend
2008-08-18 22:00:00.5312 [5]  ClientActive=True, BackupRunning=False, InBackupTime=False, InTimeSpan=False, Action=Suspend/Suspend
2008-08-18 23:02:15.5468 [5]  ClientActive=True, BackupRunning=False, InBackupTime=False, InTimeSpan=False, Action=Suspend/Suspend
2008-08-18 23:02:15.5468 [5]  ClientActive=False, BackupRunning=False, InBackupTime=False, InTimeSpan=False, Action=Suspend/Suspend
2008-08-18 23:02:15.5468 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-08-18 23:02:30.5468 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-08-18 23:02:45.5468 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-08-18 23:03:00.5468 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-08-18 23:03:15.5468 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-08-18 23:03:30.5468 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-08-18 23:58:45.7656 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-08-18 23:59:00.7656 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-08-18 23:59:15.7656 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-08-18 23:59:30.7656 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
2008-08-18 23:59:45.7656 [5]   CheckAction: a=DoNothing/Suspend force=False IsInStandby=True
Nach der Backup Time ging er nicht mehr in StandBy!
LightsOut.2008-08-18.log:
2008-08-18 01:00:01.5156 LightsOut [1] timer1_Tick
2008-08-18 01:00:11.9375 LightsOut [1] tbbRefresh_Click
2008-08-18 01:00:12.0156 LightsOut [1] AddData: found 2 clients
2008-08-18 01:00:12.3125 LightsOut [1] AddData: processed 2 clients
2008-08-18 01:00:12.3281 LightsOut [1] AddData: processed server and backup
2008-08-18 01:02:01.5000 LightsOut [1] timer1_Tick
2008-08-18 01:02:01.5000 LightsOut [1] tbbRefresh_Click
2008-08-18 01:02:01.5000 LightsOut [1] AddData: found 2 clients
2008-08-18 01:02:01.5156 LightsOut [1] AddData: processed 2 clients
2008-08-18 01:02:01.5156 LightsOut [1] AddData: processed server and backup
2008-08-18 01:04:01.5000 LightsOut [1] timer1_Tick
2008-08-18 01:04:01.5000 LightsOut [1] tbbRefresh_Click
2008-08-18 01:04:01.5000 LightsOut [1] AddData: found 2 clients
2008-08-18 01:04:01.5000 LightsOut [1] AddData: processed 2 clients
2008-08-18 01:04:01.5156 LightsOut [1] AddData: processed server and backup
2008-08-18 23:54:01.5000 LightsOut [1] timer1_Tick
2008-08-18 23:54:01.5000 LightsOut [1] tbbRefresh_Click
2008-08-18 23:54:01.5000 LightsOut [1] AddData: found 2 clients
2008-08-18 23:54:01.5000 LightsOut [1] AddData: processed 2 clients
2008-08-18 23:54:01.5156 LightsOut [1] AddData: processed server and backup
2008-08-18 23:56:01.5000 LightsOut [1] timer1_Tick
2008-08-18 23:56:01.5000 LightsOut [1] tbbRefresh_Click
2008-08-18 23:56:01.5000 LightsOut [1] AddData: found 2 clients
2008-08-18 23:56:01.5000 LightsOut [1] AddData: processed 2 clients
2008-08-18 23:56:01.5000 LightsOut [1] AddData: processed server and backup
2008-08-18 23:58:01.5000 LightsOut [1] timer1_Tick
2008-08-18 23:58:01.5000 LightsOut [1] tbbRefresh_Click
2008-08-18 23:58:01.5000 LightsOut [1] AddData: found 2 clients
2008-08-18 23:58:01.5000 LightsOut [1] AddData: processed 2 clients
2008-08-18 23:58:01.5156 LightsOut [1] AddData: processed server and backup
Das und nichts anderes wurde den ganzen Tag hineingeschreiben...
MfG
Carsten
Mainb. Intel DQ35MP
- Lights Out
Das Problem scheint mit hier zu liegen:
Nach dem QuerySuspend scheint eine andere Anwendung/Dienst den Standby zu verhindern, LightsOut denkt aber dass der Standby aktiviert wurde.
(Es fehlt der PowerEvent: Suspend Eintrag im Log).
Warum das bei dir passiert kann ich so schlecht erkennen.
Welche anderen Dienste/Add-Ins sind denn aktiv?
Wenn das Problem aufgetreten ist, kannst du dann den Server händisch in den Standby fahren?
Und steht etwas im Ereignisprotokoll?
m3Sa
Beitrag von m3Sa »
Hab nen bissel was installiert ja,
hoffe ich find alles *g*
Dienste:
- VNC Server
- VLC WebServer
- Virtual Server
- Ventrilo Server
- uTorrent
- Verschiedene SQL Dienste
- O&O Defrag
- Hamachi
WHS Console:
- uTorrent
- Disk Management
- Event Viewer
- AutoExit
- FRITZ!Box Anrufliste
Letzter Eintrag von LightsOut in der AnwendungLog ->
Auffälliger Eintrag in der Systemlog ->
Hoffe ich kann so weiterhelfen!
Hab noch nicht versucht Manuell in StandBy zu fahren da es nach Neustart des Dienstes wieder funktioniert hat ;)
MfG
Carsten
Mainb. Intel DQ35MP
- Lights Out
Eventuell verhindert Virtual Server oder einer der anderen Server (VNC, VLC WebServer, Ventrilo Server)den Standby.
Kannst du das mal testen? Zuerst ob der manuelle Standby funktioniert, dann immer einen deaktivieren.
m3Sa
Beitrag von m3Sa »
Ok,
muss nun erstmal warten bis der Fehler wieder auftritt...
Meld mich dann!
MfG
Carsten
Mainb. Intel DQ35MP
- Lights Out
