Backup status visible in popup menu
Probleme oder Fragen zu Lights-Out unter allen Windows Plattformen werden hier beantwortet
wvd_vegt
Beitrag von wvd_vegt »
I'm running the client on a Win11 tablet (touch only) and it's virtually impossible (by touch) to show the tooltip containing the last backup status info.
Is it possible to add it (as a disabled menuitem for example) to the right click (long tap) trayicon popup menu?
Zuletzt geändert von wvd_vegt am 22. Mär 2023, 13:36, insgesamt 1-mal geändert.
Re: Baqckup status visible in popup menu
Hi, I will check that.
wvd_vegt
Re: Backup status visible in popup menu
Any update on this feature request? It's still very annoying trying to show the tooltip with a finger (hoovering the mouse is alreade bad enough).
It's on the wish list for an upcoming update. No ETA yet.
wvd_vegt
That is already great! Thx
