Gesucht wird WebGuide Freeware jedenfalls 2008
DDD
WebGuide for Windows Home Server 4.113 (Jan. 18, 2008)
WebGuide is now FREE! Compliments of Microsoft and WebGuide.
To install WebGuide:
- Copy the included WebGuide MSI file to your Windows Home Server "software\addins" folder.
- Open the Windows Home Server console, load the "settings" dialog and choose the "add-ins" tab.
- The add-ins tab will show you installed and available add-ins. Choose "WebGuide4" from the
"Avaiable" tab and select install. This will install WebGuide for Windows Home Server.
- After the install completes you will be prompted to restart the console.
- Reload the console after install and load the "Settings" menu again. You should now see a
"WebGuide" tab listed.
- Select the "Configure WebGuide" button to begin the WebGuide configuration.
- Once the configuration tool loads, you can simply enter the Windows Home Server password and
select "start" to auto-configure WebGuide. This will import all of your Windows Home Server users
and configure WebGuide using the default values. For advanced configuration, choose the "advanced"
button on this page.
- After configuration, WebGuide should now be available under "Websites" on the Windows Home Server
remote access web-page.
Visit http://www.asciiexpress.com/webguide for more information and to get assistance from other WebGuide users.
* Note that if you've installed the previous beta version of WebGuide for Windows Home Server,
you will need to delete your old "license.xml" file from your WebGuide "app_data" folder
before installing the new release. This will make way for the new "unlimited" license.
WebGuide is Copyright 2007/2008 by WebGuide LLC and Doug Berrett
DIe genannte Seite ist schon lange nicht mehr verfügbar!WebGuide 4 Version 4,113
WebGuide is now free!
Compliments of WebGuide and Microsoft.
For support, please visit the community forums at http://www.asciiexpress.com/webguide
