Lichter geht in RDP-Sitzung aus ...
mrkaehler
Beitrag von mrkaehler »
Unter den "Monitored Sources" ist "Remote Access" gelistet (und auch im Setup aktiviert) - ich dachte da wär ich sicher?
Hier der Zeitpunkt im Log:
2010-11-10 10:46:54:690 [   4] DEBUG ClientCommunication: Timer elapsed
2010-11-10 11:07:44:675 [  30] DEBUG ++ Global wait timer expired, running delayed action
2010-11-10 11:07:44:675 [  30] DEBUG Action: wait for lock
2010-11-10 11:07:44:675 [  30] DEBUG Action: got lock
2010-11-10 11:07:44:675 [  30] DEBUG Reading known services from C:\Program Files\AxoNet Software GmbH\LightsOut\LightsOut.KnownServices.txt
2010-11-10 11:07:44:675 [  30] DEBUG Read 9 known services
2010-11-10 11:07:44:675 [  30] DEBUG Service RemoteAccess, has start mode Disabled
2010-11-10 11:07:44:675 [  30] DEBUG Found service Routing and Remote Access [RemoteAccess], state Stopped, mode Disabled
2010-11-10 11:07:44:675 [  30] DEBUG Service Spooler, has start mode Automatic
2010-11-10 11:07:44:675 [  30] DEBUG Found service Print Spooler [Spooler], state Running, mode Automatic
2010-11-10 11:07:44:700 [  30] ERROR BackupScheduler.EnableWakeup True: The system cannot find the file specified. (Exception from HRESULT: 0x80070002)
2010-11-10 11:07:44:700 [  30] DEBUG >>>> Hibernate force False
2010-11-10 11:07:44:700 [  30] DEBUG VailClientMonitor: suspended
2010-11-10 11:07:44:706 [  30] DEBUG BackupMonitor: suspended
2010-11-10 11:07:44:706 [  30] DEBUG RemoteAccessMonitor: suspended
2010-11-10 11:07:44:706 [  30] DEBUG IPDeviceMonitor: suspended
2010-11-10 11:07:44:706 [  30] DEBUG NetworkMonitor: suspended
2010-11-10 11:07:44:706 [  30] DEBUG CPUMonitor: suspended
2010-11-10 11:07:44:722 [  30] DEBUG ServerRuntime: suspended
2010-11-10 11:07:44:722 [  30] DEBUG   HandleServices: Spooler Status=Running
2010-11-10 11:07:44:722 [  30] DEBUG     stopping Spooler
2010-11-10 11:07:44:765 [  30] DEBUG     service Spooler Status Stopped
2010-11-10 11:07:44:765 [  30] DEBUG last event recorded: InitiatedHibernation
2010-11-10 11:07:45:472 [   4] DEBUG --- Power event Suspend ---
2010-11-10 11:07:45:472 [   4] DEBUG RemoteAccessMonitor: suspended
2010-11-10 11:07:45:472 [   4] DEBUG CPUMonitor: suspended
2010-11-10 11:07:45:472 [   4] DEBUG ServerRuntime: suspended
2010-11-10 11:07:45:472 [   4] DEBUG last event recorded: Suspend
2010-11-10 11:07:45:472 [   4] DEBUG -------------------------
2010-11-10 11:13:24:712 [   4] DEBUG The description for Event ID '1' in Source 'Microsoft-Windows-Kernel-General' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'2010-11-10T10:07:45.459000000Z', '2010-11-10T10:07:45.459000000Z'
2010-11-10 11:13:26:536 [  20] DEBUG --- Power event ResumeAutomatic ---
2010-11-10 11:13:26:536 [  20] DEBUG last event recorded: Resume
2010-11-10 11:13:26:998 [  10] DEBUG The system is entering sleep.,,Sleep Reason: 4
2010-11-10 11:13:26:998 [  10] DEBUG The description for Event ID '1' in Source 'Microsoft-Windows-Kernel-General' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'2010-11-10T10:13:24.500000000Z', '2010-11-10T10:07:46.415000000Z'
2010-11-10 11:13:27:297 [  20] DEBUG   HandleServices: Spooler Status=Stopped
2010-11-10 11:13:27:297 [  20] DEBUG Service Spooler, has start mode Automatic
2010-11-10 11:13:27:301 [  20] DEBUG     starting Spooler
2010-11-10 11:13:27:589 [   4] DEBUG --- Power event ResumeSuspend ---
2010-11-10 11:13:28:149 [  30] DEBUG Action Hibernate successfull
2010-11-10 11:13:32:593 [  10] DEBUG The system has resumed from sleep.,,Sleep Time: 2010-11-10T10:07:44.817000000Z,Wake Time: 2010-11-10T10:13:25.343000000Z,,Wake Source: 0
2010-11-10 11:13:34:168 [  20] DEBUG     service Spooler Status Running
2010-11-10 11:13:34:180 [  20] DEBUG Run:
2010-11-10 11:13:34:180 [  20] DEBUG ServerRuntime: resumed
2010-11-10 11:13:34:180 [  20] DEBUG CalendarMonitor: Resume, action cleared
2010-11-10 11:13:34:180 [  20] DEBUG VailClientMonitor: resumed
2010-11-10 11:13:34:180 [  20] DEBUG BackupMonitor: resumed
2010-11-10 11:13:34:180 [  20] DEBUG RemoteAccessMonitor: resumed
2010-11-10 11:13:34:180 [  20] DEBUG IPDeviceMonitor: resumed
2010-11-10 11:13:34:180 [  20] DEBUG NetworkMonitor: resumed
2010-11-10 11:13:34:180 [  20] DEBUG CPUMonitor: resumed
2010-11-10 11:13:34:180 [  20] DEBUG Licensee Trial 22
mrkaehler
Re: Lichter geht in RDP-Sitzung aus ...
Ich habe gerade nochmal wegen
nachgeschaut:
Aktuell ist: Service name: TermService, Display name: Remote Desktop Services, Starttype: Manual, Service status: Started
mrkaehler
Ah jetzt: Service name: RemoteAccess, Starttype: Disabled, Status: Stopped !
Das scheint aber was anderes zu sein ... jedenfalls nicht RDP ...
Edit:... das ist der ehemalige RAS-Service (http://de.wikipedia.org/wiki/Remote_Access_Service) den wolltest Du nicht wirklich abprüfen oder?
Remote Access ist nach Microsofts Sprachgebrauch der Zugriff über die Vail-Webseite. Und nur der wird überwacht.
RDP geht nicht wirklich weil das Dashboard selber auch eine RDP Session ist, die lediglich getrennt wird (also aktiv bleibt).
mrkaehler
Martin hat geschrieben:...
RDP geht nicht wirklich weil das Dashboard selber auch eine RDP Session ist, die lediglich getrennt wird (also aktiv bleibt)...
:o Das ist aber ein Jammer. Schade aber auch :evil:
Ja, das war schon am WHS v1 so. Da warte ich noch auf die zündende Idee wie das gelöst werden kann :(
