Service nicht gestartet
mrkaehler
Beitrag von mrkaehler »
Moin, ich habe die IP des WHS von DHCP auf Statisch geändert und neu gestartet:
Da finde ich sowas in der LightsOut.Service.2010-11-08.log:
2010-11-08 00:23:49:304 [  19] ERROR Unhandled exception System.ComponentModel.Win32Exception (0x80004005): The interface is unknown
   at System.Diagnostics.EventLogInternal.get_EntryCount()
   at System.Diagnostics.EventLogInternal.CompletionCallback(Object context)
   at System.Diagnostics.EventLogInternal.StaticCompletionCallback(Object context, Boolean wasSignaled)
   at System.Threading.ExecutionContext.runTryCode(Object userData)
   at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean ignoreSyncCtx)
   at System.Threading._ThreadPoolWaitOrTimerCallback.PerformWaitOrTimerCallback(Object state, Boolean timedOut)
2010-11-08 00:23:54:237 [  19] ERROR Terminating now ...
Im Eventlog steht nur lapidar:
Eventlog hat geschrieben: A timeout was reached (30000 milliseconds) while waiting for the Lights-Out Service service to connect.
The Lights-Out Service service failed to start due to the following error:
The service did not respond to the start or control request in a timely fashion.
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
  <Provider Name="Service Control Manager" Guid="{555908d1-a6d7-4695-8e1e-26931d2012f4}" EventSourceName="Service Control Manager" />
  <EventID Qualifiers="49152">7000</EventID>
  <Version>0</Version>
  <Level>2</Level>
  <Task>0</Task>
  <Opcode>0</Opcode>
  <Keywords>0x8080000000000000</Keywords>
  <TimeCreated SystemTime="2010-11-07T23:27:30.011200000Z" />
  <EventRecordID>6555</EventRecordID>
  <Correlation />
  <Execution ProcessID="556" ThreadID="560" />
  <Channel>System</Channel>
  <Computer>VailWHS</Computer>
  <Security />
  </System>
- <EventData>
  <Data Name="param1">Lights-Out Service</Data>
  <Data Name="param2">%%1053</Data>
  </EventData>
  </Event>
Allerdings steht genau vor dem letzten Event eines vom Iphlpsvc:
"Isatap interface isatap.{82552A1D-F492-47B5-AC4E-9C23E75111FE} with address fe80::5efe:192.168.10.3 has been brought up."
Das ist die interne IP des Vail. Heißt das die Netzwerkverbindung stand bis dahin nicht und das LightsOut aus der Bahn geworfen?
Re: Service nicht gestartet
Hnm, lässt sich so schlecht sagen. Kannst du mir bitte male alle Logdateien schicken und dazu schreiben wann die Umstellung war (bitte an support at axonet punkt de)?
Und was passiert jetzt nach einem Reboot, das Gleiche?
mrkaehler
Log's sind unterwegs. Beim Start eben ist alles glatt gegangen ;-)
Die Exception oben war durch den Reboot verursacht, da wurde der EventlogService vor Lights-Out beendet.
Warum der Dienst dann nach dem Reboot nicht anlief ist so leider nicht zu sagen. Im Log ist überhaupt kein Startversuch zu sehen.
Eventuell haben abhängige Dienste zu lange gebraucht.
Falls das Problem wieder auftritt bitte melden.
mrkaehler
Martin hat geschrieben:... Eventuell haben abhängige Dienste zu lange gebraucht...
Das kann sein, der Reboot fiel mitten in eine WSUS-Synchronisation ...
Ich behalte den Vail ja sowieso im Auge ;)
