McAfee TPS hatte aus unerklärlichen Gründen das Problem, dass einige McAfee Componenten nicht mehr funktionierten.
Einzige Lösung= Deinstallieren.
leider Funktionierte aber Konsole-->Einstellungen-->Addins-->Deinstallieren nicht.
Nach langen Recherchen in Web bin ich auf folgende hilfreiche und funktionierende (ich ab es selbst probiert) Info bei "Adam's tech Blog" getroffen:
--------Adam' Tech Blog--------Anfang
Unstall McAfee Total Protection from Windows Home Server (WHS)
November 17th, 2009 No comments
This is a quick article showing how to uninstall McAfee Total Protection from Windows Home Server (WHS). The instructions were not readily available on McAfees website as they have removed the KB article KB64958 from their site.
Here is a link to the uninstaller in case the one mentioned below is not working.
Corporate KnowledgeBase
Additional information for removing Total Protection Service from Windows Home Server
Corporate KnowledgeBase ID:
KB65958
Published:
June 26, 2009
Environment
Microsoft Windows Home Server
Microsoft Windows Home Server OEM implementations
Acer Aspire easyStore
HP home Media Server
Solution
CAUTION: This article contains information about opening or modifying the registry.
The following information is intended for System Administrators. Registry modifications are irreversible and could cause system failure if done incorrectly.
Before proceeding, McAfee strongly recommends backing up your registry and understanding the restore process. For more information, see: http://support.microsoft.com/kb/256986
Do not run a .REG file that is not confirmed to be a genuine registry import file.
If you have to remove Total Protection Service from a Windows Home Server (WHS), it is necessary to remove several registry keys that are removed if you use the following:
Add/remove programs
IMPORTANT: Do not use Add/remove programs to remove Total Protection from WHS. See also KB66148 on severe potential issues.
mvsuninst.exe
To manually uninstall Total Protection from WHS:
Download MVSUninst.exe from http://vs.mcafeeasap.com/MC/enu/vs45/bin/mvsuninst.exe
Run mvsuninst.exe
Restart your computer.
Click start, run, type regedit and press ENTER.
Locate and right-click the following registry key, select Delete and click Yes:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows Home Server\KnownAdditions\TopWHSaddin.msi.-8589896854554775808]
Repeat the previous step for the following:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows Home Server\RegisteredAdditions\{cfcd4bf6-203d-4213-bab4-3c140954287b}]
You are now ready to reinstall the product via the Windows Home Server console Settings screen.
--------Adam' Tech Blog--------Ende
Nun war McAfee Deinstalliert und es war 2 Uhr Nachts.
Jetzt brauchte ich aber wieder die Installation.
Da half mir die Nachricht, die ich an McAfee Online Support gesendet hatte.
McAfee antwortete mit folgender hilfreichen und funktionierenden info:
---------McAfee Online Support ------ Anfang
laden Sie bitte die folgende Software auf Ihr System herunter:
http://www.mcafeeasap.com/downloads/whs ... dIn_v2.msi
Sie muessen die MSI Datei in den Ordner SofWARE/AddIn unter Shared folder einfuegen.
Dann auf die Home Server Konsole klicken und unter einstellungen und AddIn und in der section verfuegbar dann WHS-Tool installieren Knopf klicken.
Dann in die Home Server Konsole einlogen und oben ein neues McAfee Icon (McAfee Support) das bitte anklicken und dan auf die Option Uninstall/ Deinstallieren klicken.
Bitte deinstallieren Sie starten danach neu und gehen ueber (AddInns) um die Software zu installieren.
Nach der Installation bitte erneut den home Server neustarten. Dann wieder auf die blaue Home Server Konsole gehen, den roten Total Protection Knopf (rotes M) druecken und Option Aktivieren waehlen. Dort fuer bestehendes konto auswaehlen.
Dann den code eingeben dan sie im Security Center finden.
Mein Konto Konto und Schluessel ----Kontobeitritts schluessel
Den 6 stellingen Code nehmen oder einen neuen erstellen.
---------McAfee Online Support ------ Ende
ich hoffe ,dass ich mit dieser info den ein oder anderen mit ähnlichen Problemen helfen kann.
servus
pglm
McAfee Total Protection Service Deinstall / Install
pglm
pglm: WHS Acer easyStore H340 2x 1Tbyte; PC1 Acer Veriton L460 Vista Business
Core Duo E5300 2.60GHz, 2(2x1)GB RAM, 160GB HDD; PC2 FSC Amilo Windows XP Home Edition 800 MHz 1GB RAM 80 GB HDD.
