Raspberry Pi wolproxy-1.0.3
BSmith7760
Hi, Martin
I had wolproxy running on my Raspberry Pi Zero for years. I had to recreate it, but it no longer works...did something change?
wget www.homeserversoftware.com/raspi/wolproxy-1.0.3.zip
--2021-08-31 18:32:28-- http://www.homeserversoftware.com/raspi ... -1.0.3.zip
Resolving www.homeserversoftware.com (www.homeserversoftware.com)... 45.91.101.49
Connecting to www.homeserversoftware.com (www.homeserversoftware.com)|45.91.101.49|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://www.green-it-software.com/raspi ... -1.0.3.zip [following]
--2021-08-31 18:32:28-- https://www.green-it-software.com/raspi ... -1.0.3.zip
Resolving www.green-it-software.com (www.green-it-software.com)... 45.91.101.49
Connecting to www.green-it-software.com (www.green-it-software.com)|45.91.101.49|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [text/html]
Saving to: ‘wolproxy-1.0.3.zip’
wolproxy-1.0.3.zip [ <=> ] 38.72K --.-KB/s in 0.01s
2021-08-31 18:32:30 (3.44 MB/s) - ‘wolproxy-1.0.3.zip’ saved [39652]
root@BoobNetOne:/home/pi/wolproxy# unzip wolproxy-1.0.3.zip
Archive: wolproxy-1.0.3.zip
End-of-central-directory signature not found. Either this file is not
a zipfile, or it constitutes one disk of a multi-part archive. In the
latter case the central directory and zipfile comment will be found on
the last disk(s) of this archive.
unzip: cannot find zipfile directory in one of wolproxy-1.0.3.zip or
wolproxy-1.0.3.zip.zip, and cannot find wolproxy-1.0.3.zip.ZIP, period.
Thanks,
Bob
Thanks,
Bob
Re: Raspberry Pi wolproxy-1.0.3
Thanks for reporting, will check.
I have uploaded the latest version 1.0.4. Please use this link:
https://www.green-it-software.com/downl ... -1.0.4.zip
Have a look at the updated documentation also:
https://www.green-it-software.com/pdf/R ... 01.0.4.pdf
Regards
Regards
BSmith7760
Wonderful, Martin!
Thanks!
Bob
Thanks!
Bob
BSmith7760
Hi, Martin
I tried to load it again and the latest version is no longer good...
Bob
Bob
What do you mean with "is no longer good"? Does it fail to compile? Or fail to start?
BSmith7760
root@BoobNetOne:/home/pi/wolproxy# wget https://www.green-it software.com/download/wolproxy-1.0.4.zip
--2021-12-17 04:00:23-- https://www.green-it/
Resolving www.green-it (www.green-it)... failed: Name or service not known.
wget: unable to resolve host address ‘www.green-it’
--2021-12-17 04:00:26-- http://software.com/download/wolproxy-1.0.4.zip
Resolving software.com (software.com)... 75.2.70.75, 99.83.190.102
Connecting to software.com (software.com)|75.2.70.75|:80... connected.
Location: https://software.com/download/wolproxy-1.0.4.zip [following]
--2021-12-17 04:00:26-- https://software.com/download/wolproxy-1.0.4.zip
Connecting to software.com (software.com)|75.2.70.75|:443... connected.
Location: https://www.software.com/download/wolproxy-1.0.4.zip [following]
--2021-12-17 04:00:27-- https://www.software.com/download/wolproxy-1.0.4.zip
Resolving www.software.com (www.software.com)... 184.73.183.75, 34.197.10.15, 54.164.4.68
Connecting to www.software.com (www.software.com)|184.73.183.75|:443... connected.
HTTP request sent, awaiting response... 404 Not Found
2021-12-17 04:00:27 ERROR 404: Not Found.
Then domain name is wrong, it's www.green-it-software.com
(dash between it and software).
Regards
Regards
BSmith7760
Ok...when I do this, I get this:
pi@BoobNetOne:~ $ grep wol /var/log/syslog
grep: /var/log/syslog: binary file matches
The instructions said I should get this:
Finally let’s check the system log with grep wol /var/log/syslog. You should see some lines like these
here:
pi@raspberrypi ~ $ grep wol /var/log/syslog
Sep 1 13:18:24 raspberrypi4 systemd[1]: wolproxy.service: Succeeded.
Sep 1 13:28:51 raspberrypi4 wolproxy: Running as daemon: WolProxy 1.0.4,
Copyright (c) AxoNet Software GmbH, Martin Rothschink 2012-2021
Sep 1 13:28:51 raspberrypi4 wolproxy: Waiting for interfaces to get up and
running
Sep 1 13:28:51 raspberrypi4 wolproxy: IP 192.168.1.90 netmask 255.255.255.0
broadcast 192.168.1.255
Sep 1 13:28:51 raspberrypi4 wolproxy: IP 192.168.1.87 netmask 255.255.255.0
Sep 1 13:28:52 raspberrypi4 wolproxy: open socket
Sep 1 13:28:52 raspberrypi4 wolproxy: Ready, waiting for wol packets...
Bob
here:
running
Bob
BSmith7760
Sorry, my mistake...left out a few lines after make install...
All's well now...
Thanks, Martin
All's well now...
Thanks, Martin
