Error 404 Server not found
Problems or questions with the Lights-Out Mobile app on iOS, Android and WP are answered here
Gait
Beitrag von Gait »
I'm Using Lights-Out 2 on a Windows Server 2016 Essentials server.
I've found this: https://www.green-it-software.com/4420/ ... ut-mobile/
It says:
The web service is not installed. This may happen on a desktop or standard server if you unselected IIS during first setup of Lights-Out. Do a repair install and select IIS.
But when I reinstall/repair Lights-Out I don't get a option to select IIS. What am I doing wrong?
Re: Error 404 Server not found
Please read https://www.green-it-software.com/6337/ ... ut-mobile/ and be sure to use lower case letters for the use name.
Gait
Beitrag von Gait »
Thank you, now it's working fine.
You're welcome.
