Die Verbindung zwischen diesem Computer und dem Heimserver w
mgoehlert
Re: Die Verbindung zwischen diesem Computer und dem Heimserv
Beitrag von mgoehlert »
sooooo:
C:\WINDOWS\system32\LogFiles\W3SVC2\ex120205.log:
2012-02-05 23:02:46 W3SVC2 192.168.178.10 GET /EnrollId/Id.aspx q=1328482954 55000 - 192.168.178.24 Mozilla/4.0+(compatible;+Win32;+WinHttp.WinHttpRequest.5) 200 0 0
scheint mir gleich zu sein
console.020612_5364.log:
TraceCleanup: discarding log C:\ProgramData\Microsoft\Windows Home Server\logs\console.012712_3704.log
TraceCleanup: discarding log C:\ProgramData\Microsoft\Windows Home Server\logs\console.012712_5708.log
TraceCleanup: discarding log C:\ProgramData\Microsoft\Windows Home Server\logs\console.012712_5988.log
TraceCleanup: discarding log C:\ProgramData\Microsoft\Windows Home Server\logs\console.012812_4884.log
[06.02.2012 00:02:34 1cc] m_PartnerManager.CoCreateInstance.
[06.02.2012 00:02:34 1cc] Calling m_PartnerManager.GetServerInfo.
[06.02.2012 00:02:34 1cc] m_PartnerManager.GetServerInfo returns 0x0.
[06.02.2012 00:02:34 1cc] Calling m_PartnerManager.GetServerDetails.
[06.02.2012 00:02:38 1cc] m_PartnerManager.GetServerDetails returns 0x0.
[06.02.2012 00:02:38 1cc] WARN : CreateAndConnectRdp - admin name is HOMESERVER\Administrator.
[06.02.2012 00:02:38 1cc] Connecting to HOMESERVER at path C:\Programme\Windows Home Server\
[06.02.2012 00:02:52 1cc] WARN : Disconnected, reason=2, extended reason=0
PartnerManager.020512.log:
TraceCleanup: discarding log C:\ProgramData\Microsoft\Windows Home Server\logs\PartnerManager.012712.log
TraceCleanup: discarding log C:\ProgramData\Microsoft\Windows Home Server\logs\PartnerManager.012812.log
********** Starting log, build Jan 10 2011 12:10:35 (6.0.3436.0), Process Id 8bc **********
[05.02.2012 20:23:13 b7c] CTransportConfig::ServerID Server ID is 032ef5fe-c49a-46c0-a243-6046b585b307
[05.02.2012 20:23:19 e24] CTransportConfig::ServerName reslen=0, Server name is <HOMESERVER>.
********** Starting log, build Jan 10 2011 12:10:35 (6.0.3436.0), Process Id 1020 **********
[05.02.2012 20:23:27 108c] CTransportConfig::ServerID Server ID is 032ef5fe-c49a-46c0-a243-6046b585b307
PartnerManager sollte vom 6.2. sein ...
mgoehlert
stimmt. hier ist sie:
[06.02.2012 00:00:06]
********** Starting log, build Jan 10 2011 12:10:35 (6.0.3436.0), Process Id 14f4 **********
[06.02.2012 00:02:34 1cc] CTransportConfig::ServerID Server ID is 032ef5fe-c49a-46c0-a243-6046b585b307
[06.02.2012 00:02:34 1cc] CTransportConfig::ServerName reslen=0, Server name is <HOMESERVER>.
[2012/02/06 00:02:34 1cc] ServerJoin::Invoke Calling HOMESERVER (ȰR)
[06.02.2012 00:02:34 1cc] XmlHttpRequest::Invoke called:
[06.02.2012 00:02:34 1cc] Server:HOMESERVER
[06.02.2012 00:02:34 1cc] :Path:/EnrollId/Id.aspx?q=1328482954
[06.02.2012 00:02:34 1cc] Body:
[06.02.2012 00:02:34 1cc] secure:no
[06.02.2012 00:02:34 1cc] User:
[06.02.2012 00:02:34 1cc] port::55000
[06.02.2012 00:02:34 1cc] Created MSXML 6.0 object
[06.02.2012 00:02:34 1cc] setOption succeeded
[06.02.2012 00:02:34 1cc] setProxy succeeded
[06.02.2012 00:02:34 1cc] Accessing http://HOMESERVER:55000/EnrollId/Id.aspx?q=1328482954
[06.02.2012 00:02:34 1cc] GET
[06.02.2012 00:02:38 1cc] HTTP code = 200
[06.02.2012 00:02:38 1cc] Response Text Size = 2824
[06.02.2012 00:02:38 1cc] Read hr=00000000:
<?xml version="1.0" encoding="utf-8"?><ServerId>
<Id>{032EF5FE-C49A-46C0-A243-6046B585B307}</Id>
<Admin>HOMESERVER\Administrator</Admin>
<OobeStatus>0</OobeStatus>
<OobeInProgressStatus>0</OobeInProgressStatus>
<Path>C:\Programme\Windows Home Server\</Path>
<Version>6.0.2423.0</Version>
<Error></Error>
<Master>-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
</Master>
</ServerId>
[2012/02/06 00:02:38 1cc] ServerJoin::Invoke returns hr=00000000TraceCleanup: discarding log C:\ProgramData\Microsoft\Windows Home Server\logs\PartnerManager.012912.log
********** Starting log, build Jan 10 2011 12:10:35 (6.0.3436.0), Process Id b48 **********
[06.02.2012 22:08:46 b78] CTransportConfig::ServerID Server ID is 032ef5fe-c49a-46c0-a243-6046b585b307
[06.02.2012 22:08:52 d34] CTransportConfig::ServerName reslen=0, Server name is <HOMESERVER>.
********** Starting log, build Jan 10 2011 12:10:35 (6.0.3436.0), Process Id 1048 **********
[06.02.2012 22:10:03 1244] CTransportConfig::ServerID Server ID is 032ef5fe-c49a-46c0-a243-6046b585b307
Das sieht alles sehr ähnlich bis identisch zu dem aus, was bei mir passiert ...
Gehst du eigentlich mit RDP auf deinen WHS oder hast du Monitor, Maus & Tastatur am Server ?
mgoehlert
mittels RDP, was auch klappt.
Dann bin ich jetzt langsam ratlos ... nach der Initialisierung mit dem Abgleich des Verschlüsselungszertifikates läuft eigentlich eine ganz normale RDP-Session ab ...
Jetzt habe ich noch die Idee zu prüfen warum die Installation über <homeservername>:55000 nicht funktioniert ... vielleicht liegt dort ein gemeinsamer Fehler vor :nw
s. dein post vom 2.12. mit dem Zugriffsfehler dabei ... wenn du das machst müsste iegnetlich ein Log auf dem Client angelegt werden .. poste den doch bitte mal und schau mal was dann im IIS-Log auf dem Server geschrieben wird
OlafE
Beitrag von OlafE »
mal noch ein paar Fragen dazwischengeworfen (kann sein, dass die schon beantwortet wurden, aber ich sie in der Schnelle überlesen habe):
Lässt sich die Konsole direkt auf dem Server innerhalb der RDP-Session starten?
Falls ja:
Stimmen Datum, Uhrzeit und Zeitzone auf Client und Server überein?
Funktioniert die Namensauflösung?
(auf dem Client in der Eingabeaufforderung nslookup als Befehl eingeben, in der dann erscheinenden Anzeige den Servernamen tippen, sollte die interne IP-Adresse anzeigen)
Welche Sicherheitssoftware (Virenscanner, Firewall, Security-Suite) ist auf dem Client im Einsatz?
Falls im Haushalt mehrere Clients existieren, haben alle das Problem?
Könnte eine Malware-Infektion der Grund sein? (Mit veralteten Java-Versionen fängt man sich heutzutage beim Surfen schnell mal was ein.)
Gibt es in der Ereignisanzeige Fehlermeldungen, Warnungen, Informationen mit dem Zeitstempel des missglückten Verbindungsversuchs, die weitere Anhaltspunkte geben könnten?
mgoehlert
@OlafE
nein, die Konsole lässt sich in der RDP-Verbindung auf dem WHS nicht aufrufen. Bisher habe ich mir aber nicht getraut, die Konsole noch mal auf dem WHS zu installieren.
Die Sache mit Datum, Zeit usw. hatte ich glaube schon mal gecheckt, als ich hier im Forum rumgelesen hatte. kann ich aber heute Abend gerne noch mal machen.
Die Namensauflösung kann ich auch erst heute Abend kontrollieren. denke aber, da stimmt alles, da ich vom Client auf die freigegebenen Ordner zugreifen kann.
Es existiert nur der eine Client.
Auf den Client läuft außer den Standard-Windows-Zeugs lediglich die Freeversion von AVG
Java hab ich eigentlich immer aktualisiert, Maleware kann man aber trotzdem nicht ausschließen. Fragt sich nur, wie bekommt man raus, ob da was ist?
Welche Ereignisanzeige meinst Du? Die vom Client, oder die vom WHS?
@Nobby1805
wo finde ich denn auf dem Client das Logfile?
Ooops ... gute Frage von Olaf ... aber hattest du nicht irgendwann geschrieben, dass sich die Konsole in der RDP-Session problemlos aufrufen lässt ?
Dann erst mal alles zurück und der test läuft dann wie folgt:_
bitte mit RDP auf den WHS gehen und dort versuchen die Konsoel zu starten ... was passiert ? Welche Fehlermeldung ? Screenshot !!
dann im Logverzeichnis schauen ob dort ein Logfile der Konsole angelegt worden ist .. wenn ja, diesen hier posten
mgoehlert
es passiert folgendes: 3 sek Sanduhr und das wars. Dächte, ich hätte das schon erwähnt...
und kein Logfile ?
mgoehlert
wie heißt und wo finde ich die Logfile?
OlafE
Beitrag von OlafE »
In der RDP-Session unter Start/Ausführen mal %QLOGS% eingeben und OK klicken.
Dort kannst Du Dir dann die aktuellste HomeServerConsole.xyz.log rauspicken.
mgoehlert
so. und welche von denen ist nun interessant? Außerhalb des Bildes sind dann ältere log-Dateien.
mgoehlert
auch so, und dann gibt es eine einzige log-Datei mit dem Namen HomeServerConsole.120121.2112075937.5344.log
Der Inhalt ist folgender:
Created at 21.01.2012 21:12:07
***** Started at 21.01.2012 21:12:07 ***
Pausing tracing until disk gets enough free space
