ich habe gerade wieder mal den WHS 2011 aufgesetzt und versuche seitdem den iMac zu verbinden.
Der Connector bricht immer nach Eingabe der Description für den Mac ab. In der Konsole sehe ich folgende Fehlermeldungen:
06.10.12 20:01:31,044 awacsd[67]: SecKeychain::KeychainChanged: SecKeychainItemCopyAttributesAndData returned -25303
06.10.12 20:01:31,067 awacsd[67]: SecKeychain::KeychainChanged: SecKeychainItemCopyAttributesAndData returned -25303
06.10.12 20:01:38,905 mdworker[1742]: Unable to talk to lsboxd
06.10.12 20:01:39,013 sandboxd[1743]: ([1742]) mdworker(1742) deny mach-lookup com.apple.ls.boxd
06.10.12 20:01:39,000 kernel[0]: Sandbox: sandboxd(1743) deny mach-lookup com.apple.coresymbolicationd
06.10.12 20:01:49,942 WSL[1738]: /Users/xcbusr/macbuild/Request/9AA878B8-1898-4BEA-8BA9-0B5091CFCEE7/MacUtils/RegistrationManager.m:383 Registration failed
06.10.12 20:02:03,856 Dock[263]: no information back from LS about running process
06.10.12 20:02:04,342 librariand[1748]: MMe quota status changed: under quota
Process: mdworker [1742]
Path: /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Load Address: 0x1056fb000
Identifier: mdworker
Version: ??? (???)
Code Type: x86_64 (Native)
Parent Process: launchd [1072]
Date/Time: 2012-10-06 20:01:38.935 +0200
OS Version: Mac OS X 10.8.2 (12C54)
Report Version: 8
Thread 0:
0 libsystem_kernel.dylib 0x00007fff8e4e3686 mach_msg_trap + 10
1 CoreFoundation 0x00007fff8d6a4803 __CFRunLoopServiceMachPort + 195
2 CoreFoundation 0x00007fff8d6a9ee6 __CFRunLoopRun + 1078
3 CoreFoundation 0x00007fff8d6a96b2 CFRunLoopRunSpecific + 290
4 CoreFoundation 0x00007fff8d6b8371 CFRunLoopRun + 97
5 mdworker 0x0000000105703ba9
6 libdyld.dylib 0x00007fff89b2f7e1 start + 0
Thread 1:
0 libsystem_kernel.dylib 0x00007fff8e4e5d16 kevent + 10
1 libdispatch.dylib 0x00007fff8c77e9ee _dispatch_mgr_thread + 54
Thread 2:
1 liblaunch.dylib 0x00007fff875497c4
2 liblaunch.dylib 0x00007fff875484d9 bootstrap_look_up3 + 69
3 libxpc.dylib 0x00007fff8760cc21 _xpc_connection_bootstrap_look_up_slow + 371
4 libxpc.dylib 0x00007fff8760bc82 _xpc_connection_init + 1062
5 libdispatch.dylib 0x00007fff8c77c0b6 _dispatch_client_callout + 8
6 libdispatch.dylib 0x00007fff8c77d47f _dispatch_queue_drain + 235
7 libdispatch.dylib 0x00007fff8c77d2f1 _dispatch_queue_invoke + 52
8 libdispatch.dylib 0x00007fff8c77d448 _dispatch_queue_drain + 180
9 libdispatch.dylib 0x00007fff8c77d2f1 _dispatch_queue_invoke + 52
10 libdispatch.dylib 0x00007fff8c77d1c3 _dispatch_worker_thread2 + 249
11 libsystem_c.dylib 0x00007fff8b72bcab _pthread_wqthread + 404
12 libsystem_c.dylib 0x00007fff8b716171 start_wqthread + 13
Thread 3:
0 libsystem_kernel.dylib 0x00007fff8e4e36c2 semaphore_wait_trap + 10
1 libxpc.dylib 0x00007fff8760ee1f xpc_connection_send_message_with_reply_sync + 127
2 LaunchServices 0x00007fff934a83ce send(LSBoxMessage&, LSBoxMessage&) + 28
3 LaunchServices 0x00007fff93528d4b lsbox_preflightAppLaunch + 84
4 LaunchServices 0x00007fff934b3341 _LSFindOrRegisterBundleNode + 857
5 LaunchServices 0x00007fff9350fb02 _LSRegisterNode + 75
6 LaunchServices 0x00007fff934bba0f _LSBundleCopyOrCheckNode + 1047
7 LaunchServices 0x00007fff934a35b6 _LSCopyLibraryItemURLs + 486
8 mdworker 0x000000010572b014
9 libdispatch.dylib 0x00007fff8c77ff01 _dispatch_call_block_and_release + 15
10 libdispatch.dylib 0x00007fff8c77c0b6 _dispatch_client_callout + 8
11 libdispatch.dylib 0x00007fff8c77d47f _dispatch_queue_drain + 235
12 libdispatch.dylib 0x00007fff8c77d2f1 _dispatch_queue_invoke + 52
13 libdispatch.dylib 0x00007fff8c77d1c3 _dispatch_worker_thread2 + 249
14 libsystem_c.dylib 0x00007fff8b72bcab _pthread_wqthread + 404
15 libsystem_c.dylib 0x00007fff8b716171 start_wqthread + 13
Thread 4:
0 libsystem_kernel.dylib 0x00007fff8e4e56d6 __workq_kernreturn + 10
1 libsystem_c.dylib 0x00007fff8b72bcb3 _pthread_wqthread + 412
Thread 5:
Binary Images:
0x1056fb000 - 0x105754ff7 mdworker (707.3) <105316D8-F5DF-3079-96EF-0EF0986EB053> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker
0x7fff87546000 - 0x7fff8754efff liblaunch.dylib (442.26.2) <2F71CAF8-6524-329E-AC56-C506658B4C0C> /usr/lib/system/liblaunch.dylib
0x7fff87603000 - 0x7fff87625ff7 libxpc.dylib (140.41) <FAC04D8B-680E-325F-8F0C-DD69859D0E01> /usr/lib/system/libxpc.dylib
0x7fff89b2d000 - 0x7fff89b30ff7 libdyld.dylib (210.2.3) <F59367C9-C110-382B-A695-9035A6DD387E> /usr/lib/system/libdyld.dylib
0x7fff8b715000 - 0x7fff8b7e1fe7 libsystem_c.dylib (825.25) <8CBCF9B9-EBB7-365E-A3FF-2F3850763C6B> /usr/lib/system/libsystem_c.dylib
0x7fff8c77a000 - 0x7fff8c78fff7 libdispatch.dylib (228.23) <D26996BF-FC57-39EB-8829-F63585561E09> /usr/lib/system/libdispatch.dylib
0x7fff8d675000 - 0x7fff8d85efff com.apple.CoreFoundation (6.8 - 744.12) <EF002794-DAEF-31C6-866C-E3E3AC387A9F> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff8e4d3000 - 0x7fff8e4eeff7 libsystem_kernel.dylib (2050.18.24) <C0535565-35D1-31A7-A744-63D9F10F12A4> /usr/lib/system/libsystem_kernel.dylib
0x7fff9349f000 - 0x7fff93550fff com.apple.LaunchServices (539.7 - 539.7) <DA7C602E-5E01-31B8-925D-B45360CA089F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
PS: @den Entwickler von LightsOut:
Habe den LightsOutAgent trotz nicht-Kopplung zum Laufen bekommen. Wenn ich jetzt den Mac nicht per Connector verbinde, sondern nur in den unter LightsOut zu berücksichtigenden Quellen aktiviere, funktioniert der Agent dann trotzdem, oder geht es wirklich nur per Connector-Verbindung. Im Grunde ist LightsOut nämlich der einzige Grund, warum ich den Connector auf dem Mac aktivieren würde.
